Wanted: Really tiny PC Power supplies (eg picoATX)
Well you could try regular small power supplies such as these:
http://www.scorptec.com.au/computer/12881-fsp200-60sav
http://www.scorptec.com.au/computer/10256-pti-300ar-t
Or you could try a picoPSU:
http://www.mini-box.com/s.nl/it.A/id.417/.f
Or you could track down a 1RU power supply for rackmounted server PCs. This would be quite expensive I'd imagine.
The picoPSU is obviously the smallest, but keep in mind it's a DC-DC converter so you need an addtional adapter/transformer to convert mains power down to 12V. It would also be the least powerful at 120W, but I can't imagine a 48-in-1 drawing that much anyhow.
DM I have a few open frame PSU's that may fit the bill. They even have a HDD connector ready to connect to the 48-in-1. They originally came from external HDD cases (for Mac classics :lol)
Lemme check, I'll grab a piccy with a ruler for ya...
Jacob
That picoPSU is what I had in mind Doublemint, thanks. VERY tiny.
It will add expense to require a DC power pack, but its doable.
I may as well just come out and say what I have in mind:
PSU + Jamma harness + 48-in-1 inside my desktop control panels with a power socket and a VGA out on the back. Plug in a LCD, and you're done.
Btw the base plate of the CP would be mesh to allow airflow/ventilation.
Just out of curiosity, how many voltage rails does this 48-in-1 require and what are the voltages for each one?
The 48 in 1 needs gnd, +5v and +12v. Haven't measured the current but bugger all (an amp or less easy).
---------- Post added at 10:07 PM ---------- Previous post was at 10:01 PM ----------
here it is:
http://i219.photobucket.com/albums/cc5/askjacob/DSC03860.jpg
measures: 177mm(wide) x 50mm(deep) x 30mm(high)
I have 3 of them, kept them just because they seemed great for a 48-in-1 setup. You're welcome to 1 if it will do the job (gratis!)
JAcob
