Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
Thread: 17/21 Inch COCKTAIL CABINET PLANS
  1. #11
    May 2008
    Emerald, QLD
    516
    much, thanks for that.
  2. #12
    Jul 2006
    Adelaide
    5,681
    48 Post(s)
    322 Post(s)
    So is that a decased 21" CRT?
    What finish is on the cabinet's?
    What front end do you have running?
    I see you have built a few spares as well.
    Also how are the CP's attached?
    Cheers, very nice post,
  3. #13
    Jun 2008
    Brisbane, QLD
    2,420
    235 Post(s)
    476 Post(s)
    The monitors I have been using are 21" Sun Microsystems Trinitron Flatscreen.
    The sun was the only one I could find that was symmetrical top and bottom.
    I either paint the cabs black or use a good quality German Adhesive Vinyl for the woodgrain look.
    Control panels are screwed in from the inside.
    I have been using Game Launcher with TS Gamelauncher Tools to setup lists but I think I'll switch to Mala with GLauncher Menu skin.
    The spare cabs are all gone but I am doing another run right now if anyone is interested.
  4. #14
    Jul 2006
    Adelaide
    5,681
    48 Post(s)
    322 Post(s)
    Thanks for the quick response.
    For those that would like a new cabinet you need to post your location....
    I would be interested in lots of details and photos...
    Perhaps a dedicated build thread which can be stickied for future generations to admire...
    Reason - I'm gonna try and build one of these for the 21" CRT I have in the shed..
  5. #15
    Sep 2008
    Melbourne
    13
    How much do you think it cost you all up without the computer/monitor?
    So wood, glass, buttons, legs etc?
    I'm very impressed by the finish. Well done.
  6. #16
    Jun 2008
    Brisbane, QLD
    2,420
    235 Post(s)
    476 Post(s)
    I've built a few of these cabs and have spent alot of time reseaching suppliers in my local area to keep the costs down on everything. If you don't want to spend the time looking for the best prices then you may have to spend a little more $$.
    GLASS: I got a few quotes that varied from $45 to $350. The first mob I tried gave me a piece of glass that was supposed to have 20mm radius curves but they looked more like a 50c piece. Eventually I found Canberra Commercial Windows who could CNC cut the glass, polish and bevel the edges and toughen in a choice of Float (clear) or Grey (tinted) for around $90. It takes them a week to make up.
    WOOD: You'll need 19-20mm square batten, 16mm MDF and 6mm MDF. For $70 I had Canberra Board cutting service cut everything for a complete machine in 16mm except for the lid (I already had one cut) If your'e only making one Cabinet then you should look at spending between $50-$100 for the 16 mm, depending if you cut the wood yourself or not. You'll also find that some hardware stores will cut MDF for you for a couple of dollars per cut (the less in your lungs and garage floor the better) then all you have to do is route the Control Panel Sides and cut the Lid. It's an easy solution for the inexperienced woodworker.
    $8 for a sheet of 6mm & about the same for a 2M length of 19 or 20mm batten.
    Tip: for the control panel sides it is alot easier to make one good template and use it to route out four identical ones.
    Same for the lid if you plan to make multiple machines.
    LEGS: I use 50mmx25mmx1.5 RHS (Box tube) 2M is enough which I can get supplied in 2x400mm (Vertical) & 2x500mm (horizontal) lengths all for $35.
    and 2x300mmx50mmx3mm lengths of angle for the tops of the legs (see pic) and 1x613x25 mm square tube to stabilise the cabinet across the bottom. Best quote to get a set made up was $100. Plastic end caps for the legs can be bought at Clark Rubber for a couple of dollars.
    FINISHING: Enough GOOD QUALITY vinyl to do a full machine will cost between $15-$30 this is an important part to the final look of the machine so it's not worth scrimping on.
    GLASS CORNER CLIPS: I get these machined up on a mill for $5-$10 each depending on the size of the run (min job is $100 though).
    CONTROLS: Joysticks, buttons and KEYWIZ total $110
    HARDWARE:$30-$50 eg countersunk screws,hinges,T-Moulding,enamel paint....
    I try to keep cost of each build under $500, so that would be a rough estimate of the total cost to build one of these cabs.
    The min tools needed to make a cab yourself would be:
    Screwdrivers
    Hand Drill (28mm Spade bit for button holes, costs $18 and a full range of normal drill bits)
    Jigsaw
    Table Saw
    Arc or MIG Welder
    Router (Bits: Flush Cutter/45 Angle Cutter/26.6 Radius Cutter/Slot Cutter)
    Soldering Iron & Continuity Tester
    Initial build time from start to finish (if you have all materials ready to go) was about 40 labour hours but I have completed them in 16 hours (2 days).
  7. #17
    Jun 2008
    Brisbane, QLD
    2,420
    235 Post(s)
    476 Post(s)
    Quote Originally Posted by Crafty View Post
    I get 10 Meg webspace from my ISP so I'll see what I can do about setting a page up.
    I'm cutting up a stack of wood over the next week so I'll try to update with new pics as well (more detail on routing and assembly step by step).
    I'll leave the plans at the start of the thread but if someone can put them into a PDF, that would be great.
  8. #18
    Jul 2006
    Adelaide
    5,681
    48 Post(s)
    322 Post(s)
    The Admin's here might sticky a detailed build thread..
    no harm in asking..
  9. #19
    Sep 2008
    Melbourne
    13
    Thanks for the detailed response.
    Any more info you decide to post when you build up the next few would be appreciated.
    Now for some time and money to build one up.
  10. #20
    Jun 2008
    Brisbane, QLD
    2,420
    235 Post(s)
    476 Post(s)
    Quote Originally Posted by Kaizen View Post
    I've set up a blog at: www.arcadecocktail.bigblog.com.au (now a dead link as Telstra pulled the pin on BigBlog)
    It was only just set up so theres not much there yet, but I'll add to it on a regular basis over the next week so keep checking back.
  1. Arcade Machine owners list
    By felixthadog in forum Arcade
    Last Post: 5 Days Ago, 12:44 PM
  2. Tips for building a wicked cabinet.
    By biggeorge in forum Arcade Technical and Repair Questions
    Last Post: 9th April 2018, 08:48 PM
  3. Alien "Area 51" Theme Cocktail Cabinet
    By Nidzdotnet in forum Mame Cab Projects and Discussion
    Last Post: 4th December 2008, 10:04 PM
  4. need plans for cocktail cabinet.
    By dracer in forum Arcade
    Last Post: 21st October 2008, 02:39 PM
  5. MAME cocktail cabinet with laptop?
    By c0utta in forum Mame Cab Projects and Discussion
    Last Post: 24th April 2007, 10:28 PM
