Likes Likes:  0
Results 1 to 9 of 9
Thread: Outrun PCB Road & Sky issues
    Jul 2009
    SA
    2,966
    93 Post(s)
    850 Post(s)
    Looking for a bit of guidance on two Outrun PCB's that I have.
    First one was working perfectly, but has now developed an issue where both the road area and sky are is plain orange instead of being black with textures and blue with clouds.
    Second one looks not too bad except for the right hand side of the road being a sandy colour.
    Any suggestions where to start looking?
    Dec 2016
    Barden Ridge NSW
    3,771
    192 Post(s)
    1367 Post(s)
    Quote Originally Posted by Boots View Post
    Had a similar "no sky" problem on a Daytona. In that case it was one of the upper boards needed to be re-seated. Not the same game but the same manufacturer. May be helpful.
    Jul 2009
    SA
    2,966
    93 Post(s)
    850 Post(s)
    Quote Originally Posted by Autosteve View Post
    Thanks, but already tried that.
    I actually swapped the tow CPU boards and the separate issues followed the CPU's so the Video boards look like they are good, definitely looks like a CPU board issue.
    Sep 2012
    Texas
    302
    13 Post(s)
    78 Post(s)
    It's an issue with the Sub CPU. That one controls the images.
    Jul 2009
    SA
    2,966
    93 Post(s)
    850 Post(s)
    Quote Originally Posted by channelmaniac View Post
    I swapped the CPU's, no change.
    Do you think it's the CPU itself or something around it?
    Jan 2011
    melbourne
    6,553
    244 Post(s)
    947 Post(s)
    Check RAM's around IC51/52 which control the custom Sprite Generator chip on the lower board.
    Sep 2012
    Texas
    302
    13 Post(s)
    78 Post(s)
    Also, check the ROMs containing the data - in particular, their enable lines.
    Oct 2007
    Melbourne
    5,493
    74 Post(s)
    383 Post(s)
    It's almost never the CPU that fails, it's going to be something RAM, ROM, or control logic related.
    Sic transit gloria Atari!
    Jul 2009
    SA
    2,966
    93 Post(s)
    850 Post(s)
    Yep did that and the board that has no sky or road was the opposite of the one that had partial road.
    The 7404 on the enable line looked to be working ok and inverting as it should but the signal coming in to the 7404 was different between the two boards.
  1. OutRun road issues
    By dave11674 in forum Arcade Technical and Repair Questions
    Last Post: 21st February 2019, 03:03 AM
  2. Sega Outrun Upright Road and vertical stripe problem
    By Arcad3 in forum Arcade Technical and Repair Questions
    Last Post: 15th February 2019, 12:50 AM
  3. Sega Outrun REV B board issues
    By PingoPongo in forum Arcade Technical and Repair Questions
    Last Post: 27th September 2011, 07:10 AM
  4. Sega Outrun PCB issues
    By AskJacob in forum Arcade Technical and Repair Questions
    Last Post: 19th November 2009, 10:27 AM
