Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Can anyone diagnose my CRT image?
    Aug 2019
    South Australia
    37
    10 Post(s)
    Hi all, super happy with my new (old) cabinet pick up, LAI with a Kortek chassis i think, even though i don't know the model.
    The image and colours generally look great but I have some weird interference going on which appears to be manifesting as white squiggly lines across the image, this is without the JAMMA harness plugged in so you can just see the raw monitor picture to make it easier to see whats happening.
    The video also shows the refresh rate difference across the screen, but im trying to show the white dotted lines.
    Would love the friendly experts to see if they can offer an opinion and maybe some advice, thanks so much!
    Jul 2007
    Central QLD
    2,576
    28 Post(s)
    355 Post(s)
    Possible bad earth
    More likely eht spray
    Any arcing going under yoke cap ?
    Any arcing around fbt ?
    Check neck board ground connection ro crt earth strap
    Aug 2019
    South Australia
    37
    10 Post(s)
    Thanks Ando. Can I ask what eht spray is?
    And also, what am I looking for when checking Ground and Earth connections?
    From a noobs point of view nothing looks out of place or weird around the back but I need to know what I'm looking for. I understand not to go poking my hand around the monitor so any further advice would be appreciated.
    Apr 2006
    SE Queensland
    4,110
    207 Post(s)
    885 Post(s)
    Quote Originally Posted by zer0entity View Post
    You said you've re-capped the chassis, what caps did you use?
    Personally, your best option is to send your chassis to @Jomac and get him to go over it for you.
    The only issue you might have is you've now attempted to repair the chassis yourself.
    Have a chat to Joey (Jomac) and see what he suggests.
    Aug 2019
    South Australia
    37
    10 Post(s)
    Hi mate no I haven't attempted anything at all, sorry if you misunderstood! Literally just asking questions at the moment!
    I would be honoured to summon the mighty @Jomac even just for some advice on here, thanks!
    Apr 2006
    SE Queensland
    4,110
    207 Post(s)
    885 Post(s)
    Drop him a PM.
    Aug 2019
    South Australia
    37
    10 Post(s)
    Cheers, will do!
    Jul 2007
    Central QLD
    2,576
    28 Post(s)
    355 Post(s)
    Extra High Tension, Around 28000 Volts comes from the flyback transformer to the CRT anode cap, ( that black rubber cap ) Be careful it can hold a charge even when power is off. The spray is arcing you can usually hear it, sometimes smell it. Very common in seaside environments.
    There should be an earth strap around CRT that connect to the neck PCB make sure this is sound and circuit is complete.
    Take care around High Voltage
    As John mention Joey is excellent if you are really stuck.
    Pinball, Its an Addiction
    Aug 2019
    South Australia
    37
    10 Post(s)
    Quote Originally Posted by Ando77 View Post
    Thank you for your expertise @Ando77 i really appreciate it. I have identified the parts you have mentioned. I can't see or smell anything out of the ordinary so that's good. I'm not about to go poking around though, JAMMA wiring is one thing, 240 Volt CRT's are another. I have contacted Jomac so will see if I hear anything back. I notice there seems to be a wire coming from the transformer at the bottom of the cab which runs to the big metal coin box, I assume that's as it should be and adjusting that wouldn't change/fix the issue? That's the only thing i'm willing to do myself.
    Mar 2006
    Perth WA
    1,390
    212 Post(s)
    118 Post(s)
    This looks more like a Grounding or Earthing issue , in this thread I explain pretty everything it can be , the same applies to all sorts of interference on CRT's , yours fits perfectly into category.
    http://www.aussiearcade.com.au/showt...ht=#post773846
    Not problem if you find the chassis is faulty I can sort that out for you.
  1. WMS WPC DMD Diagnostics Page Error: How to diagnose and fix
    By Wiseold in forum Pinball Repair Logs
    Last Post: 8th September 2015, 07:51 PM
  2. Technician call out in Melbourne to diagnose problem/s
    By Morphine in forum Arcade Technical and Repair Questions
    Last Post: 8th August 2014, 04:40 PM
  3. Replies: 8
    Last Post: 7th June 2012, 03:54 PM
  4. What Image ?
    By Ando77 in forum Pinball
    Last Post: 17th May 2012, 03:23 PM
  5. Please help me diagnose how to fix my TZ
    By GEEE in forum Pinball Technical and Repair Questions
    Last Post: 29th December 2010, 02:12 PM
