Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Electrohome GO7 Help
  1. #11
    Mar 2006
    Perth WA
    1,390
    212 Post(s)
    118 Post(s)
    Hi Trav , Berzerk is a slightly different Sync output so it lock frequency will put it a bit more off center than most games , while it not important on a lot of games using the G07 you will need to Join the - H Sync and -V Sync together .
    Basically you have a 6 pin input and 3 pin input connector on that chassis , The Red , Green , Blue and Gnd go in the 6 pin connector , the single neg comp Sync goes in the 3 pin connector on the V & H pins.
    This will shift the picture across , on some games you only join the Sync to H pin ( like normal monitors ) in the 3 pin connector and will sit perfect or it can be to far the other way ( opposite to what you have ).
  2. #12
    Oct 2005
    Redlands
    19,428
    172 Post(s)
    2028 Post(s)
    Spoke to Joey yesterday and reminded me to update the post.
    The board is wired exactly the same as it is in the cab with both neg H & V sync tied together so unfortunately this is a no go.
