Page 9 of 17 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 163
Thread: Gottlieb El Dorado
  1. #81
    Apr 2006
    Sydney
    1,811
    20 Post(s)
    212 Post(s)
    Quote Originally Posted by ajfclark View Post
    Be very careful if you clean the reels. Whatever ink Gottlieb used is not very resistant to liquids.
    I've heard a piece of white bread works well to clean them, but I've never tried it.
    must try that next time.. I have lost ink before but just touched up with a black sharpie
    Sent from my SM-A520F using Aussie Arcade mobile app
  2. #82
    Jul 2015
    SA
    787
    6 Post(s)
    248 Post(s)
    Quote Originally Posted by Rich View Post
    so seeing the pic with all the cam switches removed and the cam wheel still in place.......is that's why the switches are are all off because you decided to leave it in place?
    hope you took plenty of pics.
    if you decide to keep the score reels, using a bit of spit/saliva on the end of cotton buds has worked for me.
    i have found the latter of Gottlieb ink on the reels is different than earlier ones, meaning you can clean lightly, ever so lightly with say a glass cleaner.
    you might try the least used number, say a nine on the 10 thousands reel to test, again with care.
    Couldn't get the cam wheel off the shaft.
    Sent from my AGM A8 using Tapatalk
  3. #83
    Jul 2015
    SA
    787
    6 Post(s)
    248 Post(s)
    I have put everything back together. Before I pull the game to bits and repaint the cab I want to get it working at least to start a game.
    Ok. I have adjusted and cleaned things and now the game will go thru the reset sequence. The hold relay is bypassed at the moment. The NO contacts are soldered together. I put a coin in and the s relay does its thing. The scorereels reset. Ball count now goes back to zero. Targets reset. A relay does its thing as it is meant to but when the ball is placed in the outsole nothing happens.
    Any suggestions?
  4. #84
    Jul 2015
    SA
    787
    6 Post(s)
    248 Post(s)
  5. #85
    Jul 2015
    SA
    787
    6 Post(s)
    248 Post(s)
  6. #86
    Jun 2011
    Morwell, Victoria
    2,837
    43 Post(s)
    954 Post(s)
    When you say out hole do you mean manually placing the ball in the shooter lane ?
    Sent from my iPad using Tapatalk
    Putting out the feelers for my next early Gotlieb project
  7. #87
    Jul 2015
    SA
    787
    6 Post(s)
    248 Post(s)
    Sorry I meant when the ball goes in the between flippers it isn't pushing it over to the shooter lane. I cant manually advance the ball count unit. No flippers or anything on the playfield works except lights.
  8. #88
    Jul 2015
    SA
    787
    6 Post(s)
    248 Post(s)
    So step 5 in the pic isn't working.
  9. #89
    Jun 2011
    Morwell, Victoria
    2,837
    43 Post(s)
    954 Post(s)
    Sounds like the machine doesnít know that a game has been started yet , try to turn the score motor manually by hand through the door hole a few times to see if a ball gets thrown into the shooter lane
  10. #90
    Jul 2015
    SA
    787
    6 Post(s)
    248 Post(s)
    I will try that and also I will study the wiring diagram to see if I can nut it out
