Results 1 to 10 of 10
Thread: Sega Lindbergh Restore Questions
    Mar 2009
    Melbourne
    3,846
    429 Post(s)
    1378 Post(s)
    I have a single player Sega Lindbergh cab that Iím converting to 2 player. I have managed to get a 2L12B control panel and player 2 harnesses.
    Wondering what joystick this is already installed and what would be a suitable coin mech for the unit. Any help would be..... helpful!
    Cab
    Coin Mech Area
    Exisiting control panel and joystick
    Nov 2010
    Brisbane
    5,929
    180 Post(s)
    1431 Post(s)
    Looks like a Sanwa Joystick, maybe a JLF.
    If you're interested, the marquee you have is from a Namco Noir clone, or a Namco Noir. It is mounted too high on the back of the cab. I have the same one mounted on my cab and if you like I can show you how I mounted it lower down so it looks like a proper Lindbergh marquee. The marquee is supposed to sit flush with the top of the monitor, rather than being elevated.
    Mar 2009
    Melbourne
    3,846
    429 Post(s)
    1378 Post(s)
    Oh thanks man. Yeah would love to see how you did it! Thought it looked a little high haha
    Nov 2010
    Brisbane
    5,929
    180 Post(s)
    1431 Post(s)
    I'll snap a photo tonight of what it looks like from the front, but I can't get at the back of the cabinet due to shit being in the way.
    Basically, the metal mount bracket for the marquee needs to have 4 new holes drilled in it, as the current holes do not match the holes in the Lindbergh Cab. Also, because it is too high, you also need to drill holes in the back of the Lindbergh cab monitor mount. There is a steel plate on the back that supports the monitor, it's just thin steel and easy to drill through. What I did (well, what my dad helped me do, as I suck with tools) was to drill 4 new holes into the marquee mount and then line those 4 holes up and then mark where to drill on the Lindbergh cab.
    We drilled the holes and then inserted threaded rivet nuts using one of these tools. https://www.supercheapauto.com.au/p/...ol/523129.html
    The rivet nuts create a threaded hole that you can then put a bolt into to support the marquee. It ended up looking really good and you'd never know it was not original unless you looked at the back mounting plate.
    Nov 2010
    Brisbane
    5,929
    180 Post(s)
    1431 Post(s)
    @Hashman, this is what mine looks like mounted down lower. It's a lot closer to what an original Lindbergh marquee should look like. When I can finally get at the back of the cab, I will snap a photo to show you how I mounted it. It wasn't difficult, but it does require a rivet nut tool to do it properly.
  6. #6
    Sep 2013
    NSW
    1,907
    61 Post(s)
    653 Post(s)
    Hey @Hashman where did you get the 2p harness and CP?
  7. #7
    Mar 2009
    Melbourne
    3,846
    429 Post(s)
    1378 Post(s)
    Quote Originally Posted by 1.21 Gigawatts View Post
    Jasens customs for control panel and eBay for the extra player 2 harness. Iíll find the link for ya Dunc
  8. #8
    Sep 2013
    NSW
    1,907
    61 Post(s)
    653 Post(s)
    Thanks mate, I found the panel link. Do you know if the mounts on the panel mean I have to get the Sanwa jlf joysticks without the plate? Iíve found the 1p Sega panels in Japan if you need a link.
  9. #9
    Mar 2009
    Melbourne
    3,846
    429 Post(s)
    1378 Post(s)
    I bought these sticks for it as the existing stick i had didnt fit or have a plate. Jasen panel the plate holes are setup vertically instead of horizontally like the 1 player panel I had.
    https://www.austinamusements.com.au/...-joystick.html
  10. #10
    Sep 2013
    NSW
    1,907
    61 Post(s)
    653 Post(s)
    Quote Originally Posted by Hashman View Post
    Thanks Dave. Are you happy with the Jasen’s Customs panel? Is the silver behind the “mesh” look a shiny finish like the Lindbergh graphics on the rest of the cab, or is it just grey?
  1. Sega Lindbergh Marquee Help
    By namastepat in forum Arcade Machine Restoration Questions and Help
    Last Post: 22nd March 2016, 03:18 PM
  2. Sega Lindbergh - Hooking up a PC
    By namastepat in forum Arcade Technical and Repair Questions
    Last Post: 15th February 2016, 05:20 PM
  3. 2 Spicy! -New Lindbergh Shooter from Sega
    By Berty in forum News and Articles
    Last Post: 10th November 2006, 04:06 PM
  4. Sega Lindbergh
    By elvis in forum Arcade
    Last Post: 28th March 2006, 03:14 PM
