Likes Likes:  0
Results 1 to 5 of 5
Thread: Star Trek Next Generation technical help please.
    Jul 2007
    Auckland, NZ
    1,070
    50 Post(s)
    274 Post(s)
    Hi everyone
    I have a friend whose STNG cannon launchers kept moving after boot up. The test report showed 'LT LAUNCHER CAN'T FIND HOME ERROR'. Also RT LAUNCHER etc.
    The CPU board looked good (no corrosion) so I reseated all the cables on the CPU board with power off. No change upon boot up.
    Once in 'Switch Edges test', I manually triggered the microswitches underneath the cannon launchers but they both failed to register.
    These microswitch levers are triggered by the cams underneath the cannons.
    I didn't have a manual with me but I decided to change both microswitches even though there was slim chance of both failing at the same time.
    Once again the cannons keep searching for home and the new microswitches still didn't register in Switch Edges test.
    The old microswitches tested ok out of circuit.
    I had a known good CPU board so I fitted it and hey presto, no more faults.
    Once I got home, I looked at a STNG manual and a quick look at the switch matrix shows all the cannon launcher switches in column 9.
    I discovered that each launcher has two microswitches underneath, one MARK and one HOME
    Column 9 appears to be sensed by the 8 bit driver board but it was fixed by a CPU board replacement.
    How do I progress from here?
    Oct 2005
    Redlands
    19,365
    169 Post(s)
    2008 Post(s)
    I'm pretty sure those switches only register in the specific cannon test.
    Is the ribbon cable attached to j204 and the right way around?
    Jul 2007
    Auckland, NZ
    1,070
    50 Post(s)
    274 Post(s)
    The owner wouldn't have opened the back box to mess around with the cables, he's not technical. It was definitely fixed by changing the CPU board so that's where i suspect the fault is. I could fit it to another wide body with the 8 bit driver board, Twilight Zone and see what happens.
    Jun 2013
    NSW
    317
    7 Post(s)
    101 Post(s)
    Looking at the diagrams, the home and mark switches go via the 8 Driver Board to the CPU on J204. Since all of column 9 is not registering look at U7 pin 9 74LS244 on CPU board which is data line D7 to the 8 Driver board.
    Jul 2007
    Auckland, NZ
    1,070
    50 Post(s)
    274 Post(s)
    Quote Originally Posted by c_mario View Post
    Thanks a bunch, I'll just change U7 and stick it back in his game. I'll report back in about a week.
  1. Star Trek the Next Generation
    By Maxprofits in forum Common Problems listed by Machine/Manufacturer
    Last Post: 7th February 2017, 07:53 PM
