Shadow wall target assy - part wanted
LEX
5 answers to this question
Thanks @wiredoug. It’s actually the other part of the assembly that’s stuffed - you can see from the pic that the part that rubs against the metal bracket is worn and this is why the wall isn’t working (it can’t lift up high enough to latch).
Do you know if this bit has a part number?
Thanks..It’s actually the other part of the assembly that’s stuffed -....Do you know if this bit has a part number?
yep A-18779.. but i cant see mention of it anywhere.. might be SOL ? can you rotate the shaft?. hmmm.
can you use the pin off this to have your favourite fabricator make one?
https://www.pinballspareparts.com.au/04-10936-1.html
I’ve finally located one from a guy overseas thanks. Marco is getting them remade but don’t know when. It’s a part that will always wear out over time due to the design.
