Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Sprint 2 /Indy 2 Repair Log newbie
  1. #11
    Mar 2013
    Truganina, Victoria
    7,758
    407 Post(s)
    2839 Post(s)
    Quote Originally Posted by BorntoFly View Post
    I'm still concerned about the high on PIN 40. A logic probe shows RED but on osciliscope, it looks like a floating or weak signal? Any thoughts would be greatly appreciated.
    Until you get video the watchdog will bark. It’s how the board works
  2. #12
    Sep 2012
    Texas
    302
    13 Post(s)
    78 Post(s)
    Great. thank-you for this advise. I was using the Fluke incorrectly. (Noob). The VBLANK*, /VBLANK*, VRESET, VBLANK, or VSYNC all appear to be showing correct signals. And I can read the ROMs.
    Then those 2 PROMs should be fine.
    I've ordered some new RAM, could the 0000- 07ff at bit 7 error cause no boot?
    Yes. Since you can read the ROMs OK, your data bus overall (/DBUS0-7) should be fine. Focus on the RAM at K3 (/DBUS7 input and the output going through the 74LS04 at J5 - pins 5 and 6 then through the LS367 at pins 6 and 7 to the data bus)
    If you're referring to pin 40, the CPU, you need to be concerned with the transition from low to high. the /RESET signal is active low - which is what the bar over the signal name means. It should stay low for at least 50ms when powering on the system the go and stay high when running normally. If the /RESET signal is pulsing repeatedly then the CPU cannot boot and the system is repeatedly activating the /RESET signal by means of a watchdog timer. This timer gets reset repeatedly by the CPU when it is running normally. You only see it in action when the CPU can't reset the timer and the timer hits its mark then resets the CPU.
  3. #13
    Dec 2009
    Melbourne
    825
    20 Post(s)
    103 Post(s)
    Nice work. Clearly your approach is the way to go... my approach was logic probe/ttl based as my budget was about a third of yours. A lot of hair was pulled too!
    Hope you smash it soon! Good luck!
  1. Sprint 2 to repair - mainboard issues
    By Marty Machine in forum Arcade Technical and Repair Questions
    Last Post: 5th September 2014, 04:48 PM
  2. Sprint / Indy Help..
    By scratcha in forum Arcade
    Last Post: 4th June 2010, 09:30 PM
  3. INDY 2 (Sprint 2) Kee Games
    By buzzbox in forum Arcade Technical and Repair Questions
    Last Post: 30th May 2008, 07:40 PM
