Cheap 2.1 Amplifier for Cab
MarkOZLAD
I'm thinking of routing my cab's audio through a 2.1 amp. I have jamma and RaspberryJAMMA in the cab and would like to leverage the stereo from the RaspberryJAMMA where possible. (Yes I know about line level attenuators etc)
I see there are a lot of very cheap, chinese 2.1 Amps online. Has anyone here had any experience/got any recommendations for a 2.1 Amp. Don't really want to spend much if I don't have to. It will be hooked up to 8 Ohm Left/Right 10W and a sub speaker (8 ohm, forget the wattage, will check), all taken from a scrapped TV.
5 answers to this question
I've used little class D amps as above and also a Lepy 2.1 amp.
https://www.ebay.com.au/itm/Lepy-LP-838-Super-Bass-Hi-Fi-2-1-3-Channel-Stereo-Amplifier-Computer-Car-AZ/113394924306?epid=21026354003&hash=item1a66dd3b12:g:wY8AAOSwcOZb-ECO:rk:14:pf:0
Just plug into the line out of the Raspberry Pi and then into the amp and off to each speaker.
I have two of these in my Virtual Pinball
