Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: Nba jam te pcb
    Jul 2019
    VIC
    21
    3 Post(s)
    Nba jam te pcb
    Hi guys, have a nba jam board and a nba jam te board.
    The te board cones up with ram error ua13 and ua14.
    However, the game loads but u cant play it as it reverts to coin play and the mech is broken.
    The standard board is working fine.
    Should I try and swap the 2 ram from the standard board onto the te board?
    Or something else?
    Thanks
    Oct 2005
    Redlands
    19,115
    158 Post(s)
    1936 Post(s)
    how are the rams mounted?
    Jul 2019
    VIC
    21
    3 Post(s)
    I'm not sure how to explain it in arcade lingo, but here's a pic15629204947757701621875635540617.jpg
    Nov 2006
    bunbury WA
    24,333
    46 Post(s)
    1204 Post(s)
    Quote Originally Posted by Jerry View Post
    Or something else?
    Thanks
    Cant use service switch for credits?
    you can always expect change in life..except from vending machines
    Oct 2005
    Redlands
    19,115
    158 Post(s)
    1936 Post(s)
    I'm not sure how to explain it in arcade lingo, but here's a pichttps://www.aussiearcade.com/attachm...hmentid=150357
    Honestly mate unless you have the equipment to swap the rams over yourself I suggest sending the board to @Jomac
    It's worth fixing for sure!
    Jul 2019
    VIC
    21
    3 Post(s)
    Service and test switch not working
    Thanks ac. I'll PM him
    Nov 2006
    77
    2 Post(s)
    If you get/have an IC puller I'd consider giving it a go. There were kits sent to arcade operators to switch these over from NBA Jam to NBA Jam TE so with a bit of care it should be doable. Just don't bend any pins pulling them out or putting them back in.
    Dec 2016
    Barden Ridge NSW
    3,569
    182 Post(s)
    1295 Post(s)
    Quote Originally Posted by simo1412 View Post
    That is correct. That is how you upgraded the old boards. There was also a set of chips that didn't allow for the players to have big heads when it become non PC to have this feature even though the operator could simply change the settings to use normal head sizes with the normal chip set.
    Jul 2019
    VIC
    21
    3 Post(s)
    Anyone have any pullers?
    Oct 2007
    Melbourne
    5,466
    72 Post(s)
    378 Post(s)
    You can't swap the RAM chips with IC pullers, they are surface mount chips, pullers only work if the chips are socketed.
    Pulling on those will rip dozens of tracks and pads off the board and convert the board to scrap.
    Sic transit gloria Atari!
