Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Pokie reels not spinning
    Nov 2007
    Sydney
    542
    7 Post(s)
    35 Post(s)
    I'm guessing this will be a pretty dumb question but can anyone help. I've got 2 mechanical pokies that have been sitting around. I tried them last night and both have the same problem - pull the handle and the reels barely spin. Any advice on fixing this?
    Sent from my CPH1701 using Aussie Arcade mobile app
    Wanted: Aquarius backglass, any Gottlieb EM bits and pieces - nothing is junk to me
    Jul 2008
    Geelong
    2,554
    188 Post(s)
    516 Post(s)
    Dried up oil. Depending on machine some you can pull the handle till just before it releases then manually spin the reels to free them up
    Dec 2016
    Barden Ridge NSW
    3,915
    195 Post(s)
    1405 Post(s)
    Yer, it will be old solidified grease in the wheel mechs. Work the machine as you have been doing with the tray that holds the machine inside the cabinet in the out position, (they usually have a knurled bolt holding them in the closed position so you need to remove that allowing the tray to pull out). Just make sure the tray can slide out on a secure surface or the machine will tip over potentially crushing you.
    Work the mech as you have been doing but this time now that you can see the back, you will notice a number of spring loaded fingers that slide down engaging the gears on each wheel to start the wheels spinning. Inside the gears there is grease. Clean it out and apply new grease. The problem should be gone.
    If you use degreaser, be very careful not to get it on the wheel faces as you will "never" get it off them.
    Just manually scrapping out the majority and replacing it with new lithium grease is usually all that is required.
    If the time the reels spin is to short, you will notice something that looks like a gyroscope. This is the timing mechanism that determines the wheel spin time duration. Again, clean out the old grease and put in new thinner grease and this will have it spinning much faster and for longer.
    This will make the reels spin for longer before they are allowed to stop.
    Mar 2010
    Wimmera, Victoria
    7,379
    134 Post(s)
    2103 Post(s)
    Easy to fix engine de-greaser, water rinse & warm air dry, then re-oil with machine oil. DO NOT USE GREASE ON THE REELS.
    Attached Images Attached Images
    Gemini2544's 4th Pinball meet Saturday 21/03/2020
    Nov 2007
    Illawarra NSW
    7,521
    131 Post(s)
    1717 Post(s)
    Quote Originally Posted by Gemini2544 View Post
    thats a neat looking bandit. How does the jackpot reels in the top box work?
  6. #6
    Jun 2011
    Morwell, Victoria
    2,889
    44 Post(s)
    973 Post(s)
    Quote Originally Posted by rod71 View Post
    Iím pretty sure that they are manually set by the operator
    Putting out the feelers for my next early Gotlieb project
  7. #7
    Mar 2010
    Wimmera, Victoria
    7,379
    134 Post(s)
    2103 Post(s)
    Alternates 1 cent for every 10 cents pulled. Controlled by a simple relay PCB.
  8. #8
    Jul 2009
    SA
    3,002
    94 Post(s)
    858 Post(s)
    About 3 cans of Yield will do it.
    After that a bit of a spray with Lanolin will help stop the yield drying out, and yes heaps of working the mechs
  9. #9
    Mar 2010
    Wimmera, Victoria
    7,379
    134 Post(s)
    2103 Post(s)
    Quote Originally Posted by Rob1966 View Post
    Nup! it's more or less just a counter. 1 cent for every 10 cent pull.
  10. #10
    Jul 2015
    SA
    947
    11 Post(s)
    304 Post(s)
    Inox spray can fixes everything
    Sent from my GT-I9305T using Tapatalk
  1. Who Dunnit reels
    By greydog in forum Pinball Technical and Repair Questions
    Last Post: 17th October 2018, 04:13 AM
  2. score reels go beserk
    By bossninja17 in forum Pinball Repair Logs
    Last Post: 18th November 2007, 09:15 PM
