Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Green gun seems to keep firing
    Mar 2016
    WA
    102
    2 Post(s)
    19 Post(s)
    Hey All,
    Anyone here know why this is happening and what the fix would be?
    My google-fu is failing me.
    Thanks!
    Mar 2011
    Europe
    71
    11 Post(s)
    34 Post(s)
    Spark gap on the green cathode has become partially conductive. If this is the case, removing the gap is easy and quick before checking other things in the green circuit. Mentioning the monitor model and posting a pic of the neckboard would help.
    Mar 2016
    WA
    102
    2 Post(s)
    19 Post(s)
    Thanks for the reply! Iíll be in a position to pull it apart on the weekend and confirm, this is in a Daytona USA.
    Mar 2016
    WA
    102
    2 Post(s)
    19 Post(s)
    Ok it is a nanao 05a0036261 chassis
    And a Toshiba A68KJU96X Tube
    Picture below
    TIA
    Mar 2011
    Europe
    71
    11 Post(s)
    34 Post(s)
    It's a Nanao MS8-29. Desolder this component on the CRT board (lifting one leg would be enough):
    https://imgur.com/QEvFqVt
    Mar 2016
    WA
    102
    2 Post(s)
    19 Post(s)
    Thanks for the advise! Before I do it can you explain what this does exactly or share any links that may educate me?
    TIA
    Jan 2011
    melbourne
    6,551
    243 Post(s)
    947 Post(s)
    Your red/blue plug horizontal yoke is in the wrong section..Need to line up it next to the vertical plug.
    Mar 2016
    WA
    102
    2 Post(s)
    19 Post(s)
    Looks like I have a few more caps and resistors
    Mar 2011
    Europe
    71
    11 Post(s)
    34 Post(s)
    Those are not relevant. Desolder the brown spark gap closest to the blue cap. It's for protection. In case of a flashover inside the tube it attracts the spark that would otherwise damage the cathode and discharges it to ground. If it's defective it could leak to ground and that would explain the excess of green (a complete short across the cathode and ground would give a full green screen). So this is easy to check as a first step. If the green streak is still there you'll have to troubleshoot other components in the green circuit (diodes and transistors) and that's more complicated.
    Similar problem on a MS9:
    https://forum.arcadeotaku.com/viewto...31401&p=439663
    Mar 2015
    Tasmania
    1,427
    71 Post(s)
    463 Post(s)
    Quote Originally Posted by dragonlee View Post
    Genuine questions: given there are visibly two whole yoke connectors on the board, why the double? Are they just vertical mirrors, for a complete 4-in-line plug that hasn't been snapped in half? If so, why does matter which way around the plugs are, as long as the image looks right (and of course, you never mix vertical and horizontal)?
  1. FirePower not Firing :( - Fixed :)
    By DKong in forum Pinball Technical and Repair Questions
    Last Post: 24th May 2017, 11:54 AM
  2. SMB ball shooter sometime not firing
    By wako in forum Pinball Technical and Repair Questions
    Last Post: 11th December 2015, 05:22 AM
  3. Slingshot not firing...
    By Sade_Rock in forum Pinball Technical and Repair Questions
    Last Post: 20th February 2014, 11:04 PM
  4. Whitewater VUK not firing
    By robm in forum Pinball Technical and Repair Questions
    Last Post: 31st October 2010, 04:09 PM
  5. GnR not firing up correctly
    By Savage in forum Pinball Technical and Repair Questions
    Last Post: 1st January 2009, 08:20 PM
