generating directory contents from Pi (Linux)
Wondering if anyone knows how to generate a text file within linux that list the contents of a directory ? My use is for generating a list of roms within a directory in a Retropie install (linux)
Cheers,
Jed
For a [directory] and all sub directories into [filename]:
find [directory] -type f > [filename]
or for a single directory just (That's a lower case LS) but it'll include the sub directory names:
ls [directory] > [filename]
You could also use the -maxdepth flag to find:
find [directory] -maxdepth 1 -type f > [filename]
Using two >> will append to filename instead of overwriting it.
If you want to find just the zip files in a particular directory:
find [directory] -type f -iname \*.zip > [filename]
If you want to strip the .zip off the filename:
find [directory] -type f -iname \*.zip | sed 's/\.zip//' > [filename]
