tony-t Posted February 4, 2019 Share Posted February 4, 2019 Just chasing a ballast for my Spiderman, seeing if anyone has a spare please for sale. Link to comment Share on other sites More sharing options...
0 Super Moderator GIBO Posted February 4, 2019 Super Moderator Share Posted February 4, 2019 Easier and cheaper to just convert it over to a 240v ballast Link to comment Share on other sites More sharing options...
0 wise1 Posted February 4, 2019 Share Posted February 4, 2019 EC58, 58w 240v 50 This is the Aussie ballast you require and is what amd will supply you with if you order from them. This is what they sent me for Tspp Link to comment Share on other sites More sharing options...
0 toads Posted February 4, 2019 Share Posted February 4, 2019 EC58, 58w 240v 50 This is the Aussie ballast you require and is what amd will supply you with if you order from them. This is what they sent me for Tspp That would work well if the tube was 5ft long. Link to comment Share on other sites More sharing options...
0 Boots Posted February 4, 2019 Share Posted February 4, 2019 Would have thought it was an 18/20W ballast Link to comment Share on other sites More sharing options...
0 swine hoont Posted February 5, 2019 Share Posted February 5, 2019 Put in a led tube and get rid of the ballast completely Link to comment Share on other sites More sharing options...
0 pinball god Posted February 5, 2019 Share Posted February 5, 2019 Put in a led tube and get rid of the ballast completely Interested in doing this. Is this difficult to do? Thinking of doing on a rfm. What parts are required Link to comment Share on other sites More sharing options...
0 swine hoont Posted February 5, 2019 Share Posted February 5, 2019 Remove ballast and starter and connect directly. No parts required unless you add an inline fuse (1 or 2 amp), just put the high voltage to the correct side of the tube. Link to comment Share on other sites More sharing options...
0 Boots Posted February 5, 2019 Share Posted February 5, 2019 Put in a led tube and get rid of the ballast completely Or mod it with a 90’s style light board Surprised the various LE’s don’t get this as at least an option Link to comment Share on other sites More sharing options...
0 wise1 Posted February 5, 2019 Share Posted February 5, 2019 That would work well if the tube was 5ft long. This is the ballast that Amd supply for stern machines or did supply about 5 years ago. It worked just fine. But if you know better then lets hear it. Link to comment Share on other sites More sharing options...
0 toads Posted February 5, 2019 Share Posted February 5, 2019 This is the ballast that Amd supply for stern machines or did supply about 5 years ago. It worked just fine. But if you know better then lets hear it. Fluro's wattage is usually dependent on it's length. Eg a 2 foot is 18watts, a 4 ft is 36watts, a 5 foot is 58 watts. The pins have a standard 2foot 18W tube. The ballast should be matched to the wattage of the tube. The manual calls for a 13watt ballast, not sure if that's a typo as all the ballasts I've seen in sterns are 18w ballast. All though it's quite common to see 13 watt ballasts in 18watt fittings. - - - Updated - - - You can also bridge out the ballast(or take it out all together) and put a 2foot led tube in there. You must replace the starter with a fuse link(that comes with the tube) as well. It also comes with stickers to let service people know it has been converted to led. At work I try to keep the original fluro's working and try to stay clear of leds because if I changed everything to led, my job becomes redundant. Link to comment Share on other sites More sharing options...
tony-t
10 answers to this question
