Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: How to remove stubborn screws
  1. #21
    Mar 2011
    Newcastle Australia
    6,630
    397 Post(s)
    1987 Post(s)
    Quote Originally Posted by Autosteve View Post
    I get replacement "cap screws" that are #8-32 and #10-32 from this place.....
    http://www.southernfasteners.com.au/...ckets-supplier
    Pretty local to you mate and they always seem to have the right length I'm after.
    The internal grub screws are a great idea because it is less weight for the flipper coil to have to move but being blind holes, once the Allen key goes in, you have no idea if the Allen key tip has actually gone fully in the hole. Someone trys using an Allen key not fully in the hole and the problem starts rounding out the end of the Allen key hole and usually the tool itself. Now you can never get an Allen key fully in that hole again. That is the downfall of all Allen key design unless you can see the hole and take the time to check the tool is fully inserted which sometimes means cleaning crap out of the hole.
    Grub screws are when the head is the same size as the threaded section of the bolt.
    Cap screws are when the head is larger the thread.
    You can buy the replacement pawl if needed but they don’t come in the kits.
    WPC or Williams kits have the hex head coil stop bolt.
    The grub screws are a tiny Allen key size so applying pressure can snap the key.
    Bolts with the Allen Key hex head are larger sized Allen Key size.
    The Artist Formally Known As #1
  2. #22
    Dec 2016
    Barden Ridge NSW
    3,917
    195 Post(s)
    1405 Post(s)
    Quote Originally Posted by Dedrok View Post
    You can buy the replacement pawl if needed but they don&#8 217;t come in the kits.
    Yer I nearly suggested using WPC bolts. I also have #8 and #10 taps for retapping the threads. Funny, I bought them for making my own flipper base plates both Bally SS and Williams but now that I have made all I'm planning on needing, they are getting used for everything with these threads and it is amazing how much some threads are gummed up. Something I guess you don't have an issue with when you buy brand new parts but I see no reason to change parts that are not damaged or worn out plus I don't believe all the new parts are always as good as the originals quality wise.
  3. #23
    Mar 2011
    Newcastle Australia
    6,630
    397 Post(s)
    1987 Post(s)
    Yeah I clean, keep or use old parts that are still good.
    Make up bags of spares for all different makes.
    It got me through the last week.
    If the Grub Screws are OK then I re use them. If one is ruined by non fitting key attempts then I grab a spare to replace it.
    If they are ruined beyond reuse then swap out to hex head.
    If they are in doable, out with the hacksaw.
    Thought I’d clarify that “hex head” means Allen Key Bolts and that a “Hexagon Headed Flat Bolt” is a “Bolt”
  4. #24
    Jul 2015
    SA
    947
    11 Post(s)
    304 Post(s)
    Im confused. Do you hacksaw the whole shaft? After hacksawing the shaft how do you get the grub screw out?
    Sent from my GT-I9305T using Tapatalk
  5. #25
    Dec 2016
    Barden Ridge NSW
    3,917
    195 Post(s)
    1405 Post(s)
    I got corrected on the terms when I first started buying them from the suppliers. I would walk in and ask for Hex headed bolt and they would say you mean a cap screw...WTF...A screw is a thread with a taper my thinking was but they call them cap screws so that is what I ask for and then specify, countersunk, button, pan or barrel head.
  6. #26
    Mar 2011
    Newcastle Australia
    6,630
    397 Post(s)
    1987 Post(s)
    Quote Originally Posted by kimbleseven View Post
    You don’t get the grub screw out.
    Hacksaw the shaft.
    You order or use a new flipper pawl, shaft/shoe to replace.
    Have only ever had to do 1 or 2.
    I only reuse grub screws if they have been damaged, can get them out and have spares.
  7. #27
    Jul 2015
    SA
    947
    11 Post(s)
    304 Post(s)
    Where can i get a replacement pawl from? Havent seen them for sale
  8. #28
    Jul 2017
    South Australia
    1,302
    35 Post(s)
    336 Post(s)
    And if that isn't crazy enough, "cap screws" come in several designations of their own. There are "set screws" as well (having thread all the way to the head).
    If you want one of these:
    Your B.O.M. or box of bolts would read SHCS - Socket Head Cap Screw (cap screw having paralel shank section)
    SHSS - Socket Head Set Screw (set screw has thread full length)
    HHSS - Hex Head Set Screw (hexagonal head, full thread)
    Seems like the system is set up to avoid double ups in abbreviation, to help prevent confusion. A bit like how it happens with pinball titles ... some descriptions can take a paragraph without using a code system
    https://www.rtbb.com.au/product/ball...-1975-04-1980/
  9. #29
    Mar 2011
    Newcastle Australia
    6,630
    397 Post(s)
    1987 Post(s)
    Pinball Resource has them , but currently out of stock
    Never seen them anywhere else.
    @wiredoug May have spares
  10. #30
    Mar 2011
    Newcastle Australia
    6,630
    397 Post(s)
    1987 Post(s)
    Quote Originally Posted by razorsedge View Post
    https://www.aussiearcade.com/attachm...hmentid=149276
    https://www.aussiearcade.com/attachm...hmentid=149274
    https://www.aussiearcade.com/attachm...hmentid=149277
    It’s the SHCS that we want. That’s what I used in the headers of the tonna
  1. Cleaning 'stubborn' marks on playfield
    By pinballcreature in forum Pinball Restoration's
    Last Post: 13th February 2019, 01:27 PM
  2. What to use to remove tiny plunger screws?
    By hynesceltics in forum Pinball
    Last Post: 24th July 2012, 06:05 PM
  3. looking screws used in Taito cabs - flat head "speaker screws"
    By andykmv in forum Arcade Technical and Repair Questions
    Last Post: 23rd November 2010, 05:03 PM
  4. Mylar to remove or not to remove
    By ddstoys in forum Pinball Repair Logs
    Last Post: 22nd July 2008, 06:35 AM
