Results 1 to 5 of 5
Thread: Taito L-Shaped PCB Repair Log - GG#1
    Jun 2008
    Brisbane, QLD
    2,659
    259 Post(s)
    512 Post(s)
    When I first plugged the board in, it was totally dead, after replacing the crystal it came to life and was booting to garbage.
    The CPU and 74154 were removed and socketed and confirmed working on another PCB.
    All ROM sockets were replaced and a test ROM was fitted.
    Still not much change, after a bit of probing around I found one of the 75157s was faulty, replacing it brought the board back to life and the Test ROM showed two faulty RAM which were socketed and replaced.
    A set of Lunar Rescue ROMs were fitted and the game booted up but had a slight glitch, as the ship descended there were lines above and below it. If either of these lines touched one of the enemy ships it would explode as seen in the video below.
    I spent a lot of time scratching my head over this one and took a fresh look at it today.
    I could see MX4, 5 & 6 active when the ship was dropping so I started to look around that area. The pull-up resistor block checked okay so I started to check continuity from the interconnect edge connector pins back along the MX lines to the 74153s.
    Pin 36 tested open circuit so I reflowed the connector with no improvement.
    I ran a trace wire from the via directly to the pin on the interconnect and that fixed the problem.
    The board is now fully working.
    @lentildude
    Sep 2012
    Texas
    302
    13 Post(s)
    78 Post(s)
    Hey @Kaizen
    Would you be interested in reviewing a Midway 8080 doc I'm putting together?
    Jun 2008
    Brisbane, QLD
    2,659
    259 Post(s)
    512 Post(s)
    Quote Originally Posted by channelmaniac View Post
    Hey @Kaizen
    Yeah sure, shoot me a PM if it's easier.
    Sep 2012
    Texas
    302
    13 Post(s)
    78 Post(s)
    Thanks,
    I should have a first draft ready over the weekend. I'll just need an email address.
    Dec 2009
    Melbourne
    825
    20 Post(s)
    103 Post(s)
    Nice one Kaizen.
    I find these boards fun to fix. .. but sometimes a little bit on the infuriating side. Good to see a fellow spacey repairer smashing it!
  1. Taito L-Shaped PCB Repair Log (Sound PCB) Graphics Glitch
    By Kaizen in forum PCB and Monitor Repair logs
    Last Post: 23rd May 2019, 09:10 PM
  2. Taito L-Shaped PCB Repair Log
    Last Post: 12th May 2019, 08:11 AM
  3. Taito Space Invaders L shaped Taito upright
    By tevo in forum Arcade Technical and Repair Questions
    Last Post: 19th February 2019, 04:17 PM
  4. Braze kit for Taito L Shaped.
    By aaablettt in forum Arcade
    Last Post: 18th February 2016, 10:47 PM
  5. Taito L shaped shorting
    By aaablettt in forum Arcade Technical and Repair Questions
    Last Post: 26th August 2013, 08:02 PM
