Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: DJ's VP cab build
    Jan 2018
    75
    1 Post(s)
    24 Post(s)
    DJ's VP cab build
    Hi all. I have decide to build a VP table from scratch
    Been poking around this site, VPForums, VP facebook page and You Tube videos to try and work out what the heck is involved! So I thought I'd create this thread so I can contain all the info in one place, and may serve as future reference material for others.
    This will not be a quick build, as finances are tight at best, but I hope to be able to find some bargains along the way and slowly build up the gear required. If I can get 2nd hand I will but I also like things that are shiny and new so lets see how that pans out!
    Plan is to build the cabinet from scratch, I believe ply will be better for strength and also feedback systems? If so, what thickness seems best? Unless of course anyone can convince me the benefits of using an existing old pinball cabinet? I'm thinking 40" TV for playfield, but not sure that would fit in a normal pinball machine?
    My PC looks like will be this: https://support.hp.com/au-en/document/c03832938 with i7-4470 3.4GHz CPU, 8GB RAM, 500 GB HDD, but I'll replace HDD with 500GB SSD. For graphics I'm looking at the GTX1050ti: https://www.computeralliance.com.au/...gv-n105toc-4gl
    Does this sound decent enough for VPX on 2 screens at 1080? (not interested in 4k)
    I'm battling with size of playfield and cabinet at the moment. I think the lockdown bar will help decide this?
    Thanks in advance for those who decide to come along for the ride and offer help, feedback and links to make this dream a reality!
    Jan 2018
    75
    1 Post(s)
    24 Post(s)
    So I had a question regarding 4k playfield TV/monitors. Is it worth it? I assume more pixels = better definition but does that mean the tables themselves need to be in 4k and if so, are there many titles currently or a move towards this spec moving forward?
    Will the GTX1050ti card handle a 4k playfield OK?
    Aug 2006
    Adelaide
    1,538
    109 Post(s)
    347 Post(s)
    I would recommend going for a GTX1060 or higher. I've had to replace the graphics card in my VP cab 2 times over the last few years to cope with the better quality tables and newer VP versions. The first cards I had in there I saved money by getting an entry/mid level card, but because of that had to replace them sooner than if I had just bought a higher end card to start with. I recently added the 1060 6GB and it seems pretty good with everything. It is only about $100 more than the 1050ti you are looking at.
    I don't have 4k but those who I've spoken to say it does make a big difference. For 4k you'd want as high end a card as you can get to cope with all the new fancy 3d tables coming out.
    Jan 2018
    75
    1 Post(s)
    24 Post(s)
    Noted the 1050 may not cut it for 4k. But am interested to hear from those who have seen the difference of 4k for themselves and feedback if it is worth the extra $ investment to run it.
    May 2009
    NSW
    6,207
    161 Post(s)
    1428 Post(s)
    If using a regular cabinet then a 37" will drop straight in (no routering of the side walls required) 40" will fit in a standard cabinet if you router out the sides of the cab and de-bezel (which you should do anyway). 40" will drop easily into a widebody. can use up to 46" with routered sides, in a widebody.
    Existing empty cabinets can be had for not much $$ and are already ply (best for audio-based feedback using exciters) if doing so get a widebody if you can, ie: (wiki dump) it will let you use up to 46"
    It will give you a shortcut and the real cabinet and artwork helps. and much easier to source real parts for it. If i was building again i would use a 46" instead of a 40" for the playfield to fill out the cabinet better, having the useable display go as close to your rails as possible should be the goal with not much dead space around it.
    if you want to build your own from scratch then Williams widebody plans are available here, taken from a TZ: http://vpuniverse.com/forums/topic/1...cabinet-plans/
    Jan 2018
    75
    1 Post(s)
    24 Post(s)
    Thanks @Jed for the info. Whilst it would be quicker to get an empty cab (plus a quick search on AA and ebay yielded no results currently, unless I'm using the wrong terms) I am not sure how I would get it home. At least with building from scratch, then I can get the timber home myself plus have the satisfaction of knowing I built it (and only myself to blame if it breaks!) So I will probably use those plans for my build, thanks for the link.
    Does anyone know what thickness of ply is used as it's not state don the plans?
    May 2009
    NSW
    6,207
    161 Post(s)
    1428 Post(s)
    Quote Originally Posted by djgra79 View Post
    I couldn't find any online either, so I fronted up to a local Pinball seller where I used to live, he had 3x empty widebody cabs 2xPopeye 1xJudge Dredd I took the JD it was in excellent condition beautiful artwork, being a biker and a fan of Science Fiction the theme really resonated with me, awesome art on the JD one of my faves of any Pinball. Got him to fit it out with Rails, lockdown bar, coin door, glass, etc.
    but yeah making yourself from scratch also good, and it will be a lot easier to fit a screen too, and you get that made-it-yourself satisfaction. If you do go down that route, post your build thread here
    Oct 2005
    Croydon, VIC
    1,896
    93 Post(s)
    332 Post(s)
    If using a regular cabinet then a 37" will drop straight in (no routering of the side walls required) 40" will fit in a standard cabinet if you router out the sides of the cab and de-bezel (which you should do anyway)........
    I would caution against advising people to de-case, some newer TVs and monitors have no metal frame around the panel - they rely on the case to hold everything together!!!
    If you're looking to recycle an old PC (which IMO is a good way to go) then that dictates that the most powerful video card you can use is a Low Profile Nvidia GTX1050ti. Unless of course you cut the frame of the PC case so a full height card will fit, which is NOT a wise thing to do.
    If you are only looking to run 1080 (or maybe 2k) for your Playfield then that's good, as the GTX1050ti will not handle 4K at all well.
    The spec of the PC you linked to is a bit overkill for what you're proposing, so unless you're getting one nice and cheap it may be worth checking out something like this:
    https://www.ebay.com.au/itm/HP-Elite...53.m1438.l2649
    Chuck in a GTX1050ti and an SSD and you're good to go with 1080.
    Cabinet size has become a more difficult think of late - as @Jed has already suggested a 39" or 40" can fit into a standard width cab and a 46" is great for a widebody, however those monitor sizes are far less common these days as 43" seems to have taken over for some reason. This means you either go widebody into which a 43" will fit with plenty of room to spare. or you go custom.
    If you go with a custom cab you can build it to a width that will specifically fit the monitor/TV you plan to use (WITHOUT de-casing it) so looks right, however you then need to fabricate a custom lockdown bar. This isn't an issue if authenticity doesn't bother you, as you can make one out of timber that will do the job perfectly well, but it's just not the same as having the feel of stainless steel while you are playing......
    Whichever way you decide to go, make sure you take your time to research all options.
    Cheers, Chris
    Jan 2018
    75
    1 Post(s)
    24 Post(s)
    Quote Originally Posted by OzStick View Post
    If by nice and cheap you mean free then yes I have a friend who's office recently did an upgrade to their PCs so they were literally throwing them out. So yeah, plan is to pick that up this weekend and then pop the GPU in it and an SSD and I'm good to go (just need EVERYTHING else now!)
    Oct 2005
    Croydon, VIC
    1,896
    93 Post(s)
    332 Post(s)
    Ah, gotta love a freebie. Is your friend's office throwing out any more? I'd be up for catching a few of those.....
  1. Homebrew TNA inspired build (first time build)
    By matthies in forum Home Brew Pinball Projects
    Last Post: 24th December 2018, 04:31 AM
  2. New Build - First Build [Back To The Arcade - COMPLETE]
    By Macca5007 in forum M.A.M.E Emulation Projects and Discussion
    Last Post: 10th May 2015, 06:01 PM
  3. Jason's Hankin jamma build - need help pls (1st build)
    By JasonC in forum Arcade Technical and Repair Questions
    Last Post: 1st February 2009, 08:47 AM
  4. My first cab build
    By GENERALGOSH in forum M.A.M.E Emulation Projects and Discussion
    Last Post: 30th January 2009, 07:13 AM
  5. Build your own CNC
    By nigelicious in forum M.A.M.E Emulation Projects and Discussion
    Last Post: 16th March 2008, 12:45 PM
