What's the largest LCD that fits in a standard Williams Cab
  • What's the largest LCD that fits in a standard Williams Cab
    I'm sure this has been asked a million times but I can't find the answer when searching .
    I have an empty Flintstones cabinet and bought one of those Dick Smith 39.5" TV's for it, but it's too small for my liking .
    What's the largest TV I can go in that cab, even if I have to de-case one?
    - The universe is made up of protons, electrons, neutrons and morons.
    - I'm not superstitious... but I am a little stitious
    That's about it .
    maybe another inch but ain't going to be noticeable.
      As discussed when you came over to see me, it's really a matter of taking a tape measure to a few TVs to see what will physically fit.
      It's generally said that a decased 40" LED TV will usually fit into a standard width cab, otherwise consider routering a notch into the inside of the side panels to create a little extra width - maybe an extra 5-7mm per side. It's doubtful a 42" would fit and I've not seen anything in 41" so you're probably stuck between the 39.5" DSE and a yet-to-be-found 40" LED.
      Just out of interest, how much side clearance do you have in that cab with the 39.5" DSE panel??
        Zero clearance! And I will need to cut the remote sensor off or cut out a notch in the cab.
ID:	1808875 Click image for larger version
        I'm messing around with the idea of installing an old monitor bracket with a swivel in the cab and attach this tv to is so when I need to work in windows, I can lift and swivel 90 deg instead of having to work sideways like you do
          http://www.aussiearcade.com/showthre...ld-take-awhile
          This what angus has done. Maybe get some more details in what he did to decasing the bezel
          Pinball Meets...I love em
