PSU as a power supply
  • PSU as a power supply
    Hi all
    https://pcbsmoke.wordpress.com/2012/...-bench-supply/
    Interesting and informative reading about using PSU's as a power supply.
    Grab an ATX breakout board, easy power.
    SEGA love: | Nintendo love:
      Meh, just buy one of these from me:
      http://www.ozstick.com.au/product/compact-power-supply/
      I don't normally plug my wares so blatantly, but in this case i felt it was appropriate.
        I use an ATX PSU in my recent cabinet build. I think they’re excellent.
        Mine is a 550W that I picked up for $25 from the recycle Center.
        Just have to connect the two pins together. PS_On and Ground if I recall to make it always on.
        After that you should have heaps of connectors available. Just cut/strip and crimp connectors on the 12V, 5V and grounds you need. I use terminal blocks from jaycar to connect to Jamma harness etc.
        I run all my leds and amplifier as well as the game boards from it.
          Hey [MENTION=6860]Frank_fjs[/MENTION]
          You need to clear your inbox :-)
            Done! It's because my sponsorship just ended so I lost my PM storage.
