39.5''/39.5"
  • 39.5''/39.5"
    Ok i've gone through alot of headache of setting up a Virtual Pin, using an old Bingo Machine cabinet.
    Took about 5 weeks of stuffing around with my limited knowledge of visual Pinball, managed to get most of the B2B backglasses tables working, had trouble with the analogue plunger so changed it to a micro switch
    Visual pinball programs got most of them working, if i couldnt get a table working it got deleted,couldnt get Future pinball working but got about 340 VP9 working in pinballx.
    ive put micro switches under the coin reject button to so to add coins to VP
    there was a secret button underneath the plunger which works out well for the launch button
    Bingo Cabinet $200
    Old PC Intel core 2 duo CPU E7400 @ 2.80GHZ with GTX750 $150 VC $200 pc? using old subwoofer and speakers (looking for better on Scumtree)
    39.5 inch TV $275 x2
    buttons switches wires form old bingo machine $20
    225 for pin ab controller
    $150 for PF and bg tinted glass
    Flipper buttons, leaf switches spares
    about $1700 all up,
    now the biggest issue is im looking at running a 68cm CRT monitor as a backglass, will post more about how i go at a later date, why you ask? because its 4:3 and will suit the 2 monitor set up better imo.
    edit later with the CRT and as a backglass???
    The Duke of Doonside
    I like the pf on the game you're testing
      Stock it looks very similiar to mine although I designed mine on that style of cabinet. Great job but I would not be using CRT for the backglass. You can mount LCD in it and keep the original design. Use a 16:9 rotated with the little excess dropping in into the bottom out of sight. It will look HEAPS better as that back bos is very close to 16:9 already
      Brad
        +1 ^^^^^^ what Brad said.
        However, rather than positioning the "excess" portion of the backglass screen so it goes into the bottom part of the cab, consider having it protrude ABOVE the top of the backbox and you can then use it as topper display.
          It's a shame the old bingo machine had to be sacrificed for the project
            Its not that old, its a 1990 SS bingo that had battery acid damage that I couldn't get working and no tech wanted to touch
              Oh good to hear, I love those old EM Bingo machines and thought it would be a shame to see it get transformed
                I've never thought of the digital topper thing.... Have you ever configured it? Can you make it change per table etc.?
                  I have no idea! All I did was throw out the suggestion, I've never actually tried it.
                  There may be some way to set up a sort of template in a similar way to what you can do in MAME with artwork, bezels etc.
                    ok so a pop bumper bracket works well as a bracket for the micro switch on the plunger
                    pincab controller
                    the CRT is not too bad but it doesnt seem to work with the games the picture quality is pretty bad
                    the back box which i will cut down to suit the back glass lcd
                    got another dick smith 39.5 inch tv for the back glass for $255
                    http://www.ebay.com.au/itm/Dick-Smit...sAAOSwcBhWXXir
                    $299 atm on ebay use code collect15 to get a further 15% off
                      ok so i've pretty much finished my pincab
                      maybe a few tweaks as some of the back glasses are a little off centre (mainly the EM ones)
                      but here it is, more photos will come later when i get the camera working again, these are off my phone.
                      it has a tinted backglass which gives the impression of wideness,bit like a cocktail game glass, even though the actual backglass picture is still smaller.
                        Very nicely done skids. Clever use of the tinted glass over the backglass monitor to create that effect.
                        How have you positioned your speakers?
                          Here are all the photos
                          the original backbox before before it was cut down - minus the timber frame - look in later photos to notice the difference
                          had to modify the cabinet to fit the backglass tv as the bingo cabinet is slightly shorter than a standard pinball (about 50mm)
                          so only 3 bolts needed to hold the backbox now
                          rough cut for the backbox tv (later trimmed about 50mm of the front
                          tv supports
                          backbox now cut down to approx 50mm around the tv
                          front view - blue tape is where the bottom of the backglass will be and the front of the backbox trimmed right up to the TV
                          back box will later be painted black inside
                          tinted backglass - the glazier called it grey
                          inside the cabinet
                          you can see where i have the speakers at the front and woofer at the rear - speakers at the front because thats where the volume control is
                          if you look closely you can see some real pinball posts holding up the motherboard well you can see one, the rest are hidden
                          also has a tinted playfield glass to help hide the tv frame
