Dedpin : 46" 46" 2 screen pincab build : an ongoing saga
    While I have so many other projects on the go, why not another one.
    I have had a temporary setup going for a while now , so it was time to start building the cab.
    Heres some of what has been done over the last couple of weeks.
    Knocked together a cab
    Debezelled 2 x 46" LCD screens
    Fit screens into the cab
    Measured up for the back box, then assembled one
    Tested everything for fit and did some table beta testing
    Cut and fit some of the backbox trim, to suit the newer style of BG locking
    Enjoyed a few games on the huge BG
    Thats it so far
    If you like, you can check out the complete build process here Lets say_Project: DedPin_V - Virtual Pinball Cabinets - VPForums.org
Name:	cab build 1023.JPG
ID:	1863928Click image for larger version
Name:	cab build 1027.JPG
ID:	1863929Click image for larger version
Name:	cab build 1045.jpg
ID:	1863930Click image for larger version
Name:	cab build 1059.JPG
ID:	1863931Click image for larger version
Name:	cab build 1064.JPG
ID:	1863932Click image for larger version
Name:	cab build 1149.JPG
ID:	1863933Click image for larger version
Name:	cab build 1150.JPG
    UPDATE
    (full build copied over from VPF)
    I finally made a start on the cab build.
    I already had the computer built and everything set up and working for months now.
    Time to put it in a cab.
    i7 3.06 ghz
    x58A UD 3R mother board
    2 x GTS250 (16x/16x)
    4gb Ram
    700w PSU
    500 gb hdd
    All thrown together in a half case
    the initial testing on a 42" Sharp Aquos looked amazing
    Scored some ply from the last job I worked at and it just happened to be the right lengths.
    I measured up Judge Dredd and cut the sides and measured the screen for the width.
    Still debating whether to rout slots in the sides to house the screen, but for now I left it wider and installed
    temporary guides to sit the 46 on to gauge the height and position.
    Got the screen heights measured up. Works out that the backbox height will be near identical to Guns N Roses
    Did some rough measuring and there should be enough height to have a drawer tray out the back, under the vertical screen.
    Also a full sized backbox glass with lift channel and painted surround to hide the bezel.
    With a little bit of modifying, the lockdown bar locking mechanism can be made to fit so that the bar covers the whole bezel. Huge side edge bezel of 35mm.
    Decided to go with the old school look. Tried the back box from Gottlieb Spirit of 76, few mods and it will be fine. I will be making it from scratch, that head box has a home.
    Started some wiring from stuff I have laying around.
    I'm using a line filter IEC socket that I had in a driving game power supply hack as my 240v feed. Wired it to go to the 1st power socket for the computer to plug into. Also using a 240v plug to 2 x IEC plug splitter cable for the 2 LCDs.
    Made up some power switching units using relay and din rail components as well.
    I found this cool motorized USB hub. Don't know if I will put in in the front or underneath at the side. Either way, it will make life easier.
    giddyup! i'd love to a play on one, they look neat. good stuff
    Aussie : (Australian Slang) - a native or inhabitant of Australia
    Arcade : (Generic) - A type of game genre that is a fast-paced action game
    Forum : Noun (Latin/English) - A meeting or medium where ideas and views on a particular issue can be exchanged.
      Nice work, just reading the vp forum build log now
        Looks cool, I don't think I've seen anyone use a screen that big for a back glass
        "Beer, it does a belly good!"
          very neat - how did you configure the backglass monitor to ONLY use the top half of the screen??
            The software allows you to adjust the backglass picture to suit the size of the monitor
            Brad
              Brad
              Yes, I read through the VP forum and had a browse through the other stuff - WAAY too complicated for this L'il Black Duck - I'll wait for the Chinese "60in1" VP Pin board to come out
                LOL. Actually it's not that bad and once you've set it up it's all done.
                Heres a well written tutorial on how to set it all up.
                StackPath
                Brad
                  Nice one with the backbox screen would never have thought about that (out of my price range)
                    Impressive
                      very nice,
                      tempting,
                      Red
                      Shadow, Comet, PZ, Spanish Eyes, Dogies, CP, BBBB, Gridiron, Jungle Lord, Gorgar, FlyHigh Playfield and Backglass, Centrelink Kiosk, Jim Beam Dart board, Vendmax Lolly Dispenser
                      Indy500, Sprint2 & Indy2 project, TX Sector, Bone Busters Inc, Victory, Raven Gottlieb Sys80B's,Mars God Of War, F-14(project)
                      Elvira and Bluechip (given to Dad)
                        Hyperpin allows for rotating the BG, some use nvidia to rotate but I let the HP software do it.
                        I also changed the height in the setting ini so that the BG is more square and not so long. Reduced it to something like1280 x 720 or something around that.
                        Also , you have to change FP in the registry to rotate 90 deg if using the software to rotate.
                        @ Foot, I had this planned for a while, but one of the other boys is building one similar now as well.
                          Does the rotate and resize options in hp also work when using uvp active backglasses? I ask because after seeing this setup im thinking of going down the same path. Looks awesome.
                            Very, Very Nice.... I would like to see your answer to the previous post as I have an issue with some games on mine where the UVP backglass and actual games are a different size.
                              bewdiful,
                              Why do programmers get Christmas and Hallowe'en mixed up?
                              A: Because Oct(31) = Dec(25)
