Bally 6 digit display
Post up any logs or information of repairs to pinballs that could be of use to others.
  • Bally 6 digit display
    I have an issue with a Bally 6 digit display and was hoping it might be an easy fix, I swapped it to player 4 position and it does the same thing so its definitely the display, I noticed this discolored cap, would that be the issue?
    Any advice greatly appreciated, cheers
ID:	1913749Click image for larger version
    https://www.aussiearcade.com/attachm...hmentid=153095https://www.aussiearcade.com/attachm...hmentid=153096
      Fixed (hopefully)
      Put it in another machine, same, measured voltage, 167v, perfect, dialed up the voltage then back down, checked the display and is now working, woop woop.
      Now lets see if it lasts. [emoji106]
        Fixed (hopefully)
        That worked out well.
