Stern -ACDC with SHAKER MOTOR
  • Stern -ACDC with SHAKER MOTOR
    Hi Guys
    I bought my Acdc Premium and had the shaker installer. Not long after playing the acdc drop targets started to activate randomly. Later the TNT targets did the same thing or not register the hits.
    Solution
    Found that's the connectors to the target optos slightly get loose. Reseat and then place hot glue on the edges of the connectors.
    Problem gone away...
    Welcome to Aussie Arcade. Thanks for the heads up.
    Pinballs Wanted -----------> Metallica.
      Yep I had the same issue I just pushed mine back in :-) hot glue is an interesting idea where do I get that?
      Great thread :-)
      Cheers Peter
        I have had this issue too posted here...
        http://www.aussiearcade.com/showthre...highlight=Acdc
        Friend of mine is having issues with the launch not making it up to the song change saucer. Haven't been able to fix it yet.
          Great thread :-)
          Cheers Peter
          You can buy a hot glue gun with glue sticks at any $2 shop for well under $10.
            Cheers I'll check it out and do I glue the connectors together :-)
            Cheers Peter
              Not really "glue them together" - more, run a bead of hot glue along the edge where the plug meets the socket (with them plugged together). That way you can simply peel off the hot glue bead should you ever need to remove the plug with no damage.
              Cheers Peter
              This is the type of thing you are looking for - there are many types and varieties but a cheepo one will do the job just as well as an expensive one for your application.
                I think you mean $10 shop
                  Your right - generically known as a "$2 shop" there has been some price creep.
                    Cool thanks for info Mike :-)
                    Peter
                      Hi Peter
                      I bought the Hot Glue Gun from Bunnings and they come with some glue sticks.
                      The best thing is that you can always scrap it off if you need to without much effort. That is why I tried the hot glue.
                      Regards
                      Mitch
                        Originally posted by Mitchjjam View Post
                        Hi Peter
                        Regards
                        Mitch
                        Cheers Mitch I'll check them out :-)
                        Peter
                          To follow up with my fix for this problem the hot glue went hard and gave way after a while. It was easy to apply and dry but not durable enough.
                          Anyway I removed the glue and then applied good quality silicon - actually it was the same stuff used on gutters. Then left it to cure overnight. Once I got home from work the next evening I tested the fix.
                          Great!! Problem gone and has been gone for a few weeks now.
                          Cheers Mitch
