Pinball Problem Areas - Williams System 11
  • Pinball Problem Areas - Williams System 11
    As suggested by Virgil Tracy this thread is for listing common problems with Williams System 11 pinballs .
    Title : Transporter the Rescue
    Manufacturer : Williams
    Year : 1989
    Blanking error on board, replaced U25 problem fixed.
    Flippers blowing fuses, replaced coil diodes
      System 11 Pinball missing error.
      Replace faulty switch in ball trough
        System 11
        High pitched sound and some voices missing.
        Reseated U22 and U21 problem fixed
          System 11
          Lane change switch error
          Solder wires to the correct terminal
            System 11
            Left flipper was fluttering
            Turns out he screw on the EOS switch was longer than normal and had made contact with coil windings. Replaced with shorter screw.
              System 11
              Symptom: Game starts up then immediately resets.
              Fix: Slam Tilt stuck closed
                Games doing random stuff during gameplay,
                their are 10 pin resistor/capacitors on the board called SIPs these can fail with age and do all sorts of strange things to the game..
                TZ,T2,F14,FP,NF,TAF,STTNG,Hyperball
