My T2 is haunted...
  • My T2 is haunted...
    (yes, a silly thread title, but these errors are for real)
    Had some strange behaviour from my T2 recently...
    1. One time, after a few games, I was playing....
    and the "arrow lights" (that cycle up/down for skill shot) weren't cycling properly,
    yet the next row of lights to the left... WERE cycling up/down. (?!?!)
    2. Sometimes, when I turn on the machine.... I get NO playfield lights at all. (GI & flashers work though)
    3. Sometimes when I turn on the machine... it's all fine, then... while playing, many lights flicker randomly.
    4. If that's not enough, sometimes while playing, the speech samples play about 5 seconds after they're triggered!
    eg: Ball hits skull dropdown target... 5 seconds later... "load the cannon" (?!?!)
    Any ideas?
    NOTE: This is my 1st pin - I haven't had it too long - and I barely know one end of a soldering iron from the other.
    sounds like bad connectors on the boards to me
      Ditto. Check connectors.
      Mr_Staypuft, I moved thread to the appropriate forum.
      Dan
        Thanks guys, and sorry Dan, hadn't seen that subforum.
        PS.. any tips as to WHICH connectors to look at?
        There's rather a lot of them....
        (and I've very much got my "L plates" on)
          board on right at bottom gi connectors look for burnt connections clean pins with sandpaper you will need a mulity meter to check ohms while off or voltage Dc when on just earth the neg probe
            Hmmm....
            Might have to get one of the techs from work
            to come over and have a look.
            thanks
              Try putting some batteries in it.
              Sounds real stupid, but these games can 'fake' some real wierd faults if they don't have batteries in them.
              Cheaper test than getting a tech out.
              Any arcade, pin, juke, probs in Adel, just message me.
              Some people are like Slinkies. Not really good for anything, but they bring a smile to your face when pushed down the stairs.
                it has batterys in it
                the holder is wired off the board
                sorry I cant help though mate
                  They should be labelled J120 and J121, if that helps you a bit more.
                  The biggest board and look to the bottom left corner of that board.
                    Thanks PB '74, when I get my tech friend over,
                    I'll point him in that direction.
                    No worries Bwodster...
                    you're always welcome over for a bit of Magical Drop 3...
                    (beware, Mrs_Staypuft may pwn you at it!)
                      my magic drop needs much improvement but my puzzle bobble is flawless!
                        Ahh, till I get my own PB to practice on,
                        we'll have to delay our playoff.
