Tz topper lighting question
  • Tz topper lighting question
    Am in the early/middle stages of building a topper for my Tz and currently have it lit up via GI's. What I want to do is put a globe in the eye section that will come on when 'the power' insert is lit.
    is there any issues in simply connecting my light directly from the insert globe holder wiring or do I need to do something extra like a diode on that globe?
    thanks in advance
    Mimic the same lamp holder and put the diode if you can just in case you use a globe standard globe but if using an led its a diode in itself so there’s probably no need to
