Williams System 11B - Cyclone - No Display
  • Williams System 11B - Cyclone - No Display
    Hello Everyone,
    I have a Williams Cyclone which has a display problem. When I power on the machine, everything works fine except the LED Displays.
    I Checked Fuses F1, F2, and F3 and they all seemed fine. I then swapped out the display assembly with the same unit from Big Guns which I is known good and still no displays.
    I am stumped. If the display unit isn't the issue and the fuses are good, what else could it be?!?
    Any help would be greatly appreciated.
    How did you test fuses?
    F1 on the power supply board is for the displays, a 250mA slow blow.
    Just looking at a fuse isn't good enough to ensure it is okay. Test with a fuse tester or multi meter.
    Check 3J5 pin 6 on the power supply for 5VDC.
    3J5 pin 1 is ground.
