Due to a large amount of spamers, accounts will now have to be approved by the Admins so please be patient.
- 0
LW3 coil diagnosis - reality check
Recently Browsing 0 members
Question
JOC469
Currently trying to diagnose an issue with my LW3 - the centre drop targets are not resetting. Usually coil 6L will reset them, but currently nothing. Testing so far:
After going into diagnostics I get no faults showing.
Select the centre drop target coil to test - no response.
Select the right drop target coil to test - works.
Bridge the two coils together and activate right drop target - both work (so coil is ok).
Bridge the two coils together and activate centre drop target - no response.
Short transistor on main board to ground for centre drop target coil - works (probably should have just done this to start with).
So I am thinking the issue is with the wiring between the coil and the ground return somewhere? Start checking the harness connectors and test for continuity?
Thanks in advance for any help. Brain is currently fried after a massive start to the year and I just want to make sure that I am on the right track.
1 answer to this question
