Humming motor question
  • Humming motor question
    Hey 'all,
    Recently I've noticed a humming/buzzing in my pinny (Tales From the Crypt) which I can feel through the cabinet. I thought it was one of the flipper solenoids, but have noticed it's coming from the motor that moves the Crypt target up and down.
    The humming (obviously) is only present when the motor is activated ie moving up or down.
    Is this a cause for alarm? Will it eventually cause a dead short/start blowing fuses?
    I havnt opened it up to have a look yet.
    I also took off the Cliffy protector I installed... It was affecting gameplay too much ie airballs and changing the path of the ball. Much better now
    If the rummour is at a low level over the background music and speach is normal if it is higher than backgroud that means the gears are kind of used
    some of them need lubrication !!!!
    If humming is heard on speakers it means a decoupling capacitor on the voltage line is dry and need to be replaced !
    Marius
    www.pinball.ro
    Originally posted by Mickey Juice
    Hey 'all,
    : Your supplier for pinball parts !
      Sorry, I should have explained better.
      It's not an 'audible' hum, I can 'feel' it buzz/vibrate through the cabinet as it moves up and down.
        Sounds pretty normal I remember on my Data East Last Action Hero i could feel a slight hum when the crane motor was working.
          Thanks. Just asked as it's never done it previously.
