No display on regular WPC dmd
    Collecting practically anything Mancave (Pinball, Arcade, Toy, Beer & Sport related)
    Over 2000 Sports games on DVD - www.allsportdvd.com
    Dmd driver board has a blown fuse or high voltage issue. Colour dmd doesn't use the high voltage section of the dmd driver board.
    Try swapping dmd driver board with another machine to verify this is the issue.
    Sent from my ALP-L29 using Tapatalk
      Colourdmd doesn’t use the high voltage but the plasma does
      Perhaps a blown fuse or the high voltage section has a fault
      Have you checked the voltages at the connector?
          Did you reconnected the high voltage cable? This cable is removed & not used on a ColorDmD.
          Dang just read you found the cable missing.
