ToM - Trunk Error - A new solution
    Theatre of Magic - Trunk Fix Kit
    If modifying you own DC Motor Controller board: these are the connection points:
    Tangles' Pin Parts.
    Pinball Replacement Boards - Designed and Manufactured in Australia
    http://tanglestech.com
    [MENTION=7008]rodneypapish[/MENTION]
      Hey [MENTION=13619]Tangles[/MENTION],
      If you’re looking for another project, the Twilight Zone Proximity switch is no longer available anywhere. This is switch 26, and often causes issues with TZ’s.
      I’ve had ongoing problems with mine and have searched worldwide. There were two aftermarket versions also made, but neither of these is still in production.
      It’s not an overly complicated design, so should be easy for you.
      Below is a pic of my aftermarket ‘improved design’ one for reference.
      I’d be happy to trial anything that you come up with!
      PS - nice job on the trunk boards. If mine play up I’ll be in touch!
        Eddy boards for TZ (ramp and trough) are in development. They will be available very soon.
        Tangles' Pin Parts.
          I recently purchased your trunk pcb pre this fix. Is there an mod to utilise your previous pcb or would I have to purchase another smart trunk pcb
          I just has a thought, the sensor can also be utilised for the magna saves is that correct?
            The smart eddy board works in all three loacations on ToM.
            If you own original version boards of the Smart Eddy and want to take up this new feature, PM me and I we can work out an upgrade path.
            Tangles' Pin Parts.
