Shadow wall target assy - part wanted
  • Shadow wall target assy - part wanted
    Does anyonspare bracket and plunger assy for the wall target they could sell me? Mine is worn and the wall wonít reach high enough and so isnít working. Everywhere seems out of stock:
    https://www.marcospecialties.com/pinball-parts/Ap
    Sorry the part number is A-18752
    https://www.marcospecialties.com/pinball-parts/A-18752
      no thats the assembly number ... lookup the individual parts
      try this in usa.. 02-3972-2 plunger-drop target
        Thanks [MENTION=12190]wiredoug[/MENTION]. Itís actually the other part of the assembly thatís stuffed - you can see from the pic that the part that rubs against the metal bracket is worn and this is why the wall isnít working (it canít lift up high enough to latch).
        Do you know if this bit has a part number?
          Thanks..It’s actually the other part of the assembly that’s stuffed -....Do you know if this bit has a part number?
          yep A-18779.. but i cant see mention of it anywhere.. might be SOL ? can you rotate the shaft?. hmmm.
          can you use the pin off this to have your favourite fabricator make one?
          https://www.pinballspareparts.com.au/04-10936-1.html
            Iíve finally located one from a guy overseas thanks. Marco is getting them remade but donít know when. Itís a part that will always wear out over time due to the design.
