What pins have been coming thru the Dedshed
Post your SS Pinball Project pictures and logs here.
  • What pins have been coming thru the Dedshed
    Yeah, I'm still hanging on to the shed, haven't been "moved on" yet.
    So in between doing my own restores , will get back to EK soon when parts come, and working stupid hours while tending to the 3 legged dog, I take on some machines.
    Some to just give a quick strip and clean, and then test. Others require much more being container pins.
    Some just need a tweek and some adjustments.
    Xenon
    TSPP
    Black Knight 2000
    Rollercoaster Tycoon http://www.aussiearcade.com/showthre...37#post1076837
    Swords of Fury
    http://www.aussiearcade.com/showthre...93#post1089693
    Cyclone
    https://www.aussiearcade.com/showthr...18#post1096318
    Whirlwind
    https://www.aussiearcade.com/showthr...92#post1099092
    https://www.aussiearcade.com/showthr...76#post1113176
    X's and O's
    https://www.aussiearcade.com/showthr...59#post1111959
    South Park
    https://www.aussiearcade.com/showthr...26#post1128226
    Joker Poker
    https://www.aussiearcade.com/showthr...25#post1136725
    DrDude
    https://www.aussiearcade.com/showthr...08#post1138308
    Odds and Evens
    https://www.aussiearcade.com/showthr...41#post1147941
    Whitewater
    https://www.aussiearcade.com/showthr...49#post1154149
    So 1st up was a quick couple of adjustments to a Xenon. Just needed the flippers sorted out, some Gi fixed , the tube shortened and put in the correct position with post moved as well. Also the ramp switch where the ball kept catching.
    Next up was TSPP.
    This had garage door problems. So installed stronger coils to the door and VUK. Changed the shit LEDs for some cool frosted dome type. Made a big difference. Also after not booting up, ended up finding the Neutral line had come out of the plug that goes to the transformer.
    This pin had already been stripped and cleaned/fixed earlier. It's currently on site going thru some severe testing and will be back for a clean before going back to its home.
    For my other keeper rebuilds, links are here
    Playboy : http://www.aussiearcade.com/showthre...layboy-Rebuild
    Evel Knievel : http://www.aussiearcade.com/showthre...-Knievel-resto
    Next up is why I started the thread. Am going through the system 11 games. They are in a bad way.
    Black Knight 2000
    This was in a bad way. I'm not doing playfield restores but just general repairs, clean and make look/play nice.
    First was to make a list of what needed doing. Keeps growing.
    Flat batteries so did a battery mod while making the list.
    Time to start stripping and cleaning , remove the top PF to see what I'm in for, and the first thing I see is a red wire running from the top flipper wrapped around the harness and straight thru to the Aux board. Sigh.
    Play fields are filthy but have Mylar mostly. Which can be bad
    Heaps of broken plastics and posts. Plus broken wrong type posts.
    So ordered some posts , red as no clear in stock and needed red for upper PF.
    Also clear plast protector set to help stabilise the broken ones.
      So with limited time to work on this only doing a few hours at a time, I've gone for the strip and clean gradual approach.
        Added cool white frosted dome Gi as I go , and red frosted dome for the posts.
        Polished all the rails and scoops etc next.
        The scoop was actually milky it was that bad.
        and screwed in the new posts, with freshly polished screws obviously.
          Nice work mate !
          That BK2000 sure got a flogging.
          Will come up a treat with good clean, Leds and re-rubber.
          I was looking for a pinball for the missus as she is super keen on Pinball and misses the Spidey we had.
          Ended up getting a really nice BK2000 from Pinball Shed. ( Thanks Tony and team )
          Missus really enjoys this one, More than Metallica, It crazy because BK2000 is a super fast and much harder Pin than METLE.
          Amazing how the pops always seem to be in such good nick, yet you look at pops on other 25+ year old pins are sad,
          unsure of the secret ?
          As most are well aware the big letdown is the mylar bubbling on these
          Anyways, thanks for the resto thread and all the pics
          Look us up if you need any reference info.
          Ando
          Pinball, Its an Addiction
            Yeah Ando.
            The Mylar bubbling is a big let down, as well as wear up top where there is none. . But other than that it all looks fine.
            The habbitrails are both broken and really need replacing. but got them workable for now.
            Yeah it's fast. I think mainly because the flipper coils get upgraded from the 11630 to the newer 11629. Bit of over kill.
              Give the flippers a bit of a clean, makes a difference. Added some red titans. Makes them pop.
              Installed flipper kits and upgraded to the newer type without the plunger spring.
              No wonder the red upper flipper dodgy wiring went directly to the 50V on the Aux board. The EOS on the lower flipper along with the upper flipper actuator switch were not only non existent but not even close to operating.
              So made up a set out of a kit.
                Added a set of mirror blades, left them unpeeled for now, and then went to work underneath cleaning all the light boards and inserts.
                Then it was time to add the insert LED's. Colour matched the inserts to make it pop.
                  Then it was time to re install the upper pf and led the rest of it.
                  Red under the lane guides and in the pop bumpers.
                  To clean lane guides and reusable posts, I just use a bowl with soapy water to soak and the clean with a small paint brush.
                  For screws and metal posts I use the drill with some novus2 and a scotchbrite pad.
                  They come up sweet.
                  For those that might not know , the upper play field is hinged and locks forward for ease of access.
                    With the play field mostly done it was time to check coils, switches and lamps, among other oddities and missing or non working bits.
                    There was a few switch errors, one being the 3rd lock. Board had been hacked and wire soldered direct.
                    This still ended up being intermittent so will need further investigation at a later date.
                    For now I did the connector and resolder on the board and still intermittent.
                    Then there's the usual gi connectors that always have a burnt plug. So fixed that. Was only backbox panel luckily but the relay board was hacked and shorted too. Did the connector and resolder on the relay but think it's stuffed. Will need replacing. At least the bottom string works for now which is better than none.
                    Unplugged the interconnector board and checked and it was really nice [emoji1303]
                    Pulled the CPU board and replaced a locked on lamp row transistor. This board was in much worse shape and had wrong parts and bad solder jobs all over it.
                    The lamps weren't completely locked on as they tested good in test but were mostly always on in gameplay.
                    Instead of TIP42 it had 44s.
                      So after a few weekends of a few hours here and there and a lot of tweaking, it looks and plays so much better.
                      Ended up pinching a decent original plunger, play field hinges and few other parts from the next machine in the line up.
                      Peeled the mirror blades and had a heap of games til 3am as more were coming up and this is being sent home.
                      Still needs a few bits and pieces but is mostly done.
                      Here's the result
                      So FH and WW turned up today and BK2K goes home. SoF is next in line.
                        Looks great Edy. One of the best soundtracks out there and amazing light show.
                          Great thread. Interesting read. Thanks. 👍
                          Sent from my SM-G900I using Aussie Arcade mobile app
                          Pinball...I can't get enough !!!
                            Nice work. What a huge improvement.
                            Thanks for sharing.
                              This game really used to annoy me, but after spending so much time playing it the last few weeks, it has grown on me and the soundtrack doesn't irk me anymore.
                              The lighting is amazing, the flasher work alone. And I haven't even upgraded them to LED yet.
