Medusa soundboard
  • Medusa soundboard
    Iv lost sound on my good old medusa. He started talking on and off now gone completely. Capacitor? Thank you.
    Check the connectors first as the easiest fix, if no dice send them off to Ken, he does a great job.
      Yep, clean and reseat connector and try again. 80%+ of all SS problems are sorted by repining corroded connectors.
        Give the volume control inside the coin door, and the two speech and sound volume trimmer pots on the Squawk & Talk board a little tweak while sounds should be playing to see if they're the issue.
        These volume controls are a common source of intermittent problems due to dust contamination buildup on the swiper arm.
          Thanks guys. Sorry for the late reply. Iv actually lost quite a few things that should be happening. Might be time for a reco?
            Does the LED on the sound board flicker on power up then flash four times to say it's passed power on self tests?
              Ok no light. It actually made a noise today but no talking etc.
