Thomas the tank engine. TTTE.
Non Commercial Pinball Projects.
  • Thomas the tank engine. TTTE.
    I've just done something very stupid.
    I used the words Thomas and pinball in the same sentence in front of my three year old son.
    I might have to start selling some projects and just work on the AA and now Thomas pins.
    The Thomas one will be just an Arduino running a Hankin/Homepin solenoid board.
    Edit: As is usual in my projects this idea has changed.
    It'll be very simple and built on an old Orbit1 or Top Score playfield.
    I might have some cheap cocktail cabs for sale soon and I might just check the boards in the Phantom and sell them and the cabinet too.😉
    Cheers Trev
    or you could buy an AC/DC, or a Cactus Canyon
    there is a Zac with a train theme
      What's wrong with a Thomas the tank theme?
        Nothing it's just another project.
          Well that's the topper sorted.
          [emoji1]
            You know you can't say no to that cute little guy
              Oh yes I can. But then I feel bad and build him a pinball machine.😉
                just get an old working EM with crap playfield and put some Thomas decals down for a playfield and on the plastics, couple of Thomas toys and be done with it lol
                  I've rebuilt my old discoloured Orbit1 playfield with Gottlieb Pop Bumpers, Data East Slingshots (from the spare Phantom of the opera playfield) and a few Hankin bits. After the playfield was assembled I checked the power supply I bought for the AA pin (on hold for a while) to see if it would fire the solenoids ok. I just wired it to a coil with a push button in the positive line.
                  That worked fine so I mounted the psu, an Arduino Mega and two 4 way Mosfet boards to the underside of the playfield and started to wire it up. Once the solenoids were wired in I moved on to the switches. I still have the +5v (common) line to add to one side and the flipper wiring to do and the start button. One wire from each switch goes to a digital pin on the Arduino and a pulldown resistor and the other wire on each switch is looped together and goes to +5v.
                  Flipper switches will switch the +5v going directly to the mosfet board so won't need to be heavy duty and I can use a low power relay operated by the Arduino to turn the flippers off while it's in attract mode. All the lighting will be handled by one string of addressable leds driven by one pin on the Arduino. (I love that idea)
                  Yes it's in a Getaway HS2 cab.
                  Day one
                  Day two
                  Day three.
                  I knew that hole was there for a reason. Hmmm. Smoke machine maybe.😉
                  Translite artwork being worked on.
                  I've ordered 1.8" high blue 7 segment led displays for the scoring and balls in play displays.
                  Cheers Trev
                    Whats the mofset driver boards your using Trev? What input voltage do they need?
                      What a great project, Trev. Will you have it ready to bring to Pinfest so Christopher can show off his skills?
                        I hope so if I can get it to work properly and if there's room. I've got a bit of programming to do but it's going to be a simple game.
                          They take a 5v signal from the Arduino and will drive 24 to 28v for the Gottlieb and Hankin coils I'm using. They are IR540 mosfets and can supposedly drive up to 100VDC at 33A or so the Ebay ad says.😉
                            Suggestion: Change the letters "T.A.N.K" to "Y.A.R.D"
                              I will be changing the common line on the switches to gnd as the Arduino Mega has internal pull up resistors but doesn't have pull downs which I'd need to use the +5v as a return line.
                              Cheers Trev
                              Users Viewing Topic: 0 members and 4 (guests)
