Gyrus begina
  • Gyrus begina
    OK, posting a pic of my one off pinball, Gyruss. I'm about to start cutting the holes to fix all the light gfx in the playfield.
    I've sort of figured out all the rules. Going to play similar to the video games. Need to knock down targets to warp.
    To do on the lower playfield.
    Finish guides in upper left.
    Cut all lights and holes
    Arrange playfield
    Ramp
    Ball kicker
    I need to start on the top playfield after I get this one right
    Be good to see, love Gyruss arcade game!
      Looking good Geoff!
      Regards,
      Johns-Arcade.
        Looking good. When you warp does will anything change ie lights colour? Is the lock to the lower right the warp lock (guessing) once you have knocked down the targets. Looking forward to the progress
          nothing better than home made cant wait for further updates.
            I'm having 2nd thoughts about the 2nd playfield. Have to wait and see on that bit for now. Worse case I will make a wire chute to take the ball back to one of the lanes
            Might use the ramp as a warp? or a ran around the outside loop.
            I want to get the playfield funtioning first to finialise a few rules. Need to know how hard it will be to get certian shots first.
            I will get the flippers and bumpers running first so there is some reation to it. Scoring is only keeping track of what you hit anyway
            Should get a good feel of it then but at the moment I am going on gut instinct on the skill shots on whatever else.
            I would like to get a 2nd playfield in there tho.
            I was thinking of using the targets as ships hit.40 ships one wave. Each wave is one warp, 2 warps between planets.
            As for the multi ball, challange stage Get to a planet, multi lights, get multi. And get all 40 targets without losing a ball and get the jackpot.
            Top gates would be the multiplier. I will have a few rollovers as well.
              Are the electronics going to be taken for an existing game? Sorry if it's been discussed before
              btw, Shouldn't you start every post with "Good News Everyone!"
                No, I would like to integrate a wide panel lcd as the headboard and run a pc otherwise it will be a standard pc with some additional hardware
                The guys at pinmame have already go the hardware for the lights and other outputs.
                Inputs thru one the the key matrix chips available
                Just need to work out the software side.
                  the earth should spin in the middle like it does on the TMNT pin to throw the balls around a bit
                    let me know if you need a keybord encoder for the inputs geoff i got a couple here if you need them
                      hey nice theme, which lends itself well for pinball implementation.
                      looking forward to progress, the pinmamehw boards are NLA, but im sure youll find a substitute.
                      does that mean youre writing your rules within the pinmame system or your own home brew?
                      a couple of advancing lamps and corresponding targets would work well for "attacking waves" with the warp up the ramp (can hear the sound effect now!)
                      even bonus rounds of squentially lit targets or a sequence to complete would also keep the theme authentic. i was looking at a galaga or gauntlet theme before coconut island. 2 ball multi would be the double shot power up ! (available at the start of each "wave")
                      make it start at pluto and go to the sun!
                      do you have a seperate website to document progress?
                      most interested.
                      regards
                      "Oh my mistake..you are wrong."
                        Out of all of it, writing the rules would be the hardest. So many things you can do.
                        I was thinking of 1 hit of each target is a hit of a ship. I was thinking of having a hit counter down the bottom. 4 segments that light for each wave. 1 wave would be the 10 targets. (2 x 4 and a dual). After all 4 segments are lite, the warp is activated (Ramp shot?).
                        Multi ball will light after the first 10 targets are hit. Then you have to do a double around the loop or complete the ramp to activate the ball trap for multiball. Might have this timed too.
                        Trying to find all my small files and woodwork tools Not easy doing the cutouts for the lights. WOuld be nice to have a CNC router on hand
                        This is a learning curve at the moment. I have plans for another one. So many things are affected by one change.
                        As for a web site? No time for that stuff It can stay here at the moment.
                          Impressive stuff Prof, looks like it could be a really good, I like it.
                            funny, im playing with 3 steppers right now! (and its BIG)
                              Wow, this thing is starting to take a life on of it's own. Becoming organic.
                              I have mocked up the plastics layout to get a better idea of how crowded it might be before I finish the light layout.
                              I have scrubbed the idea for an upper playfield on this one. I'll save that for the next one
                              As it is, the upper is a separate playfield. Need to get the flipper hit right to go into the multiplier rollovers
                              Or you can go for the loop shot. Might make it a bonus that doubles up to a point. 1k, 2k, 4k, 8k, 10k ?
                              I'm going to keep the scoring realistic too . Hate these machines with these 16 million point shots. Same scoring, just drop the last 3 -5 digits
                              I am going to make a wire ramp the will aim the ball into the left drain area.
                              I have cut the bumper holes. I need to enlarge them a little yet.
                              Oh, and has anyone got a bumper mounting plate the don't need ?? Saves me making one
                              One thing from the video game that I will put in is the star field. I intend to have 3 or more shades of blue 3mm leds. Might even tint them. I will have the earth in the centre of the playfield with the leds radiating out in a similar pattern to the vid. The playfield is going to be mostly black with the inserts giving most of the gfx. I might have a few more yet after the star field is done. I intend to mount the leds into the plastics as well to continue the path as fully as possible. I was thinking of going circular at first but I might work out the perspective to give a better effect. This will run independent of the rest so will be on from power up as in the vid
