Total Playfield restoration
  • Total Playfield restoration
    This has already been posted on another forum in great detail, so i wont elaborate too much.
    Here are some before and after pics of a disaster of a Stern Wild Fyre playfield. The paint was just falling off and to save it, large blocks of colour needed to be redone. The while process will be on my website flipperescue.com.
    But here is the apron before;
    and after;
    Playfield was a mess as you can see
    It gets totally rubbed back
    Blocks of colour then replaced
    Same with this area - done in stages of each colour, Ive already stuck down the laminations and primed
    These bits are tricky - i try to avoid having to replace wording but sometimes you have no choice
    Here are both areas after restore
    Process is done right round the whole playfield and then its finally clear coated. The large section at the lower pf has been replaced as has the blue - most detail has been reworked and wording has been replaced - much by hand.
    Heres the final product. 4 coats clear coat and then a sand back, then clear coat again give a mirror like finish. What was a write off is almost factory new again
    Few more pics here with furniture and without
    This once looked like this!
    Supplier of licensed Gottlieb restoration tools.
    Fricken awesome!
      amazing stuff, thanks for sharing
        UN-real. Your colour matching is bang on. That's fantastic work. What brand/type of paints do you use?
          Very nice!
          What do you to mask the areas not being painted and for stencils?
          "Beer, it does a belly good!"
            paints
            All done with Pantone soft enamels and airbrush - colour matching with Pantone colour chart - gives a good indication of the colour but may not be exact.
            Clear coat is specifically designed to be compatible with these inks - yes ive seen it all turn to melted cheese before!
            Masking is done with low tac vinyl. I cut by hand and make templates on the computer - these are then computer cut - this is how the apron is done etc,
            see here..
              great work! just remember to update your profile with your location
              In My "arcade":
              More to come!
                Great stuff, Gavin. I see you have made yourself "at home" already.. Can't wait to see the cabinet repaint !!
                  Wow..! I can only dream of such skill.
                    Nice work.
                      WOW!
                      you are an artist!....
                      great work!
                      will be keen to watch & learn!
                        Nice work!
