wire guides on playfield
  • wire guides on playfield
    hello, just done a 2 pac clear coat on my F-14 TOMCAT playfield and in the process of putting back together just wondering what you use to hold in the wire guides and how high off the playfield do they go.
    Normally they have a barb on the bottom of the legs to hold them tight in the timber . If they are a bit loose you could hold them in place with a drop of gel-type super glue from under the playfield . As for height they normally are inserted until the legs are flush with the underside of the playfield .
