Twilight Zone Restoration
  • Twilight Zone Restoration
    Well its been a little bit too long since i've done a restoration thread, so here goes.
    This TZ used to be mine many years ago, and the guy who bought it had let it go a fair bit, added quite a few mods, never cleaned it and it had developed quite a few issues over time - many to do with the fact he shorted things adding mods and thier associated wiring!
    Here are a couple of pics when i got it - doesn't look too bad, but was pretty average close up
ID:	2111358 Click image for larger version
    First thing was to gt the game running - it was resetting, heaps of switches not working and flippers were really weak. After a lot of mucking around, i rebuilt some of the power driver board, replaced pins and plugs, repaired fliptronics board and there were also some issues on the MPU to sort out.
    Once it was functioning, i started the tear down
ID:	2111360 Click image for larger version
    Then into the cabinet
ID:	2111362 Click image for larger version
    Once sanded, had to do quite a bit of bogging and sanding, also screwed and glued the front section as it had very slight separation
    These are the only pics i have of the playfield mostly stripped
ID:	2111365 Click image for larger version
ID:	2111366 Click image for larger version
ID:	2111367 I have old pictures of previous TZ tear downs, so i just stripped everything off without taking any pictures as i will use the old ones for reference.
    So the playfield got sent to Savage for some work, and all the parts are dumped in crates under other machines ready for cleaning.
    So i then hooked into painting and preppeing the cab for decals - no progress pictures of this part sorry - just the end result. Got the young fella to help out, and installed protectors
ID:	2111369 Click image for larger version
ID:	2111370 Click image for larger version
    Then started reinstalling some hardware after a cleanup/repaint of some parts, machine looks like this now
ID:	2111373 Click image for larger version
    Progress from this time on will slow up, heading to ACS later today, then Monday morning am booked in for a double hernia operaiton....yay! Hence the rush to get all the heavy lifting stuff done. So once i am back on my feet a little, i will clean all the mechs and playfield parts.
    Also, here's a little teaser for this absolute gem (different TZ obviously) which will be feauring in an upcoming restoration thread.....
ID:	2111374 Click image for larger version
ID:	2111375 Click image for larger version
ID:	2111376 Click image for larger version
ID:	2111377 Click image for larger version
    I think this one, you should name Lazarus
      Watching this one
        Big job ahead of you, respect! The colour on that PFlooks badly faded, considered a PF swap considering all the work you are doing anyways ?
          Good to see another robm restor thread, it's been a while. Good luck at ACS and with the operation.
          I have propelled the ball along the proper trajectory and been rewarded
            Hey Rob, I don't want to bring your private life onto the forum, but is that possum shit I see in the second TZ?
              Haha. Very observant sir. That is in fact one of the original possum pins. Sold it 'as is' years ago, now bought it back 'worse as'
                The last restoration is in good hands and gets plenty of love.........finally took your GC score as well......it only took about a year......lol. As has been said great to see another restore thread from you robm
                Pinball...I can't get enough !!!
ID:	2114839 Click image for larger version
ID:	2114840 Click image for larger version
ID:	2114841 Click image for larger version
ID:	2114842 well slowly recovering from the double hernia operation. Seriously don't recommend this surgery for an easy way to get time off work. I will spare you the nasty details but let's just say I was bright purple in places where you shouldn't be.... Can move around a bit but far from active at the moment.
                  So have been cleaning parts, installing the boards and small light bits of cabinet hardware.
                  Also eliminated one potential source of resets on wpc wide body games by getting rid of the 'z' connector and direct soldering the wires.
                  No pic at the moment but have also been building an Mpu which has been nice easy work while I'm still half crippled.
                    What was the purpose of the z connector? Stern still use these too. I'm guessing there isn't a male and female connector in this type?
                      It’s only purpose was to make assembly easier at the factory.
                        That TZ is looking pretty damn good Rob. Did you get your trophy home??
                          Haha. Bill should be bringing it up in the next little while I think
                            You will need to think ahead about things like this now you are a champ Rob
                            Dave
                              While I agree that this PF does look faded, I've discovered that due to the quantity of PFs required, B/W used multiple manufacturers (Churchill - CCC, Thomas A Grant - TAG, and Sun Process - SP) to each produce TZ playfields and these manufacturers used slightly different colour pantones and clear coats in their production. As a result not all TZ playfields look the same (and possibly some age better than others). For those interested, here's an article on the various playfield manufacturers http://www.lasvegasplayfields.com/?page_id=19
