is anyone else having issuues connecting to pinside ,, it just times out
pinside ? issues
General Pinball Discussion.
Yeah I think JJP had it taken down because they were getting bad press thereIn: Houdini, Iron man, SWLE, TWDLE, Whitewater, WOZ and Xmen
Out: Avengers Hulk, BOP, BSD, Demo man, Elvis, Flintstones, Frank Thomas Big Hurt, Frankenstein, The Getaway:HS2, Gorgar, Grand Slam, Hobbit, Judge Dredd, Lord of the Rings, METPrem, Roadshow, RZ, Shadow, Spider-Man, STTNG, WCS, Wheel of Fortune, Wild life, WWELE
- 4 likes
Apparently the datacentre they use has technical issues
https://mobile.twitter.com/pinsidedo...65295541452800
What sort of place puts water sprinkler systems in a server room ! I used to install Halon Gas Fire Suppression systems in Server rooms. You get a fire, the gas is released, starves the fire of oxygen and then the fire goes out...no damage ! Unless you are a human in the room, then you die real fast as the oxygen is removed from your lungs ! Modern systems now use nitrogen gas as this reduces the oxygen level enough to kill the fire but not kill the humans !!!! Footnote: Terminator's are not effected by Halon Gas...
- 2 likes
