Twilight Zone drop target Assembly A-17153
General Pinball Discussion.
  • Twilight Zone drop target Assembly A-17153
    So doing my resto and found about half a dozen parts retailers have this assembly listed as a part for twilight zone...
    What is the go here...Tz doesnt have a drop target?? If this is true, I now have a new assmebly for sale !
    https://www.pinballspareparts.com.au...e/a-17153.html
    https://pu-parts.com/1-bank-smart-dr...get-assembly_2
    Not aware of the drop target assembly being used in the TZ. The compatibility list seems incorrect- possibly copied off each other, as both are also missing The Shadow which does use this drop target
      Shadow is different and has a small coil with a pin (plunger). Same coil as in Funhouse Rudy head.
      Seems to be your basic trip coil.
      You’d substitute BSD in for TZ I’d assume
        Shadow has one of these aswell the funhouse style cool your picturing is for the brick wall mech
          Sttng uses this one.
