My RC's
  • My RC's
    Hi there, I'm new to the forum and just noticed this sub-forum.
    RC is my main hobby at the moment.
    I compete in Rock Crawling and Scale 4x4 comps.
    Here is my custom 2.2 Sportsman that I built.
    Youtube of the chassis being punched on our CNC Turret Punch.
    http://youtu.be/VW4kiGHksWA
    This is my Scale truck.
    I also have a couple of Tamiya models.
    Sand Scorcher.
    Bruiser.
    I also have a cheap NQD Tear Into jet boat that I recently upgraded.
    http://youtu.be/p_pFlWQM5-g
    I hope you guys like them.
    I like the Bruiser!! How long is it???
      Thanks, It is a nice truck.
      Here is a quote from the Tamiya web site.
      【 Specifications 】
      ●Length: 525mm, Width: 278mm, Height: 275mm, Weight: 3.2kg ●Track width: 200mm (Front), 218mm (Rear) ●Wheelbase: 287mm
      ●Tire Width/Diameter (F/R): 60/123mm ●Type 540 Motor ●Longitudinally-Mounted Motor Shaft-Driven 4WD ●Front & Rear 6-Pinion Differential Gears ●Front & Rear Oil Dampers
      ●Gear Ratio; 1st Gear=1:54.63 (4WD), 2nd Gear=1:40.49 (2WD), 3rd Gear=1:27.92 (2WD) ●Requires an Electronic Speed Controller (sold separately)
      I just measured it, the 525mm is accurate.
        Strooth!!!!
          Yeah, it's pretty big and heavy.
          Here is a link to my build thread, if you want to see how the kit went together.
          Build thread on Scale4x4rRC
            Intense!!! Nice
