rc Helicopter problems
  • rc Helicopter problems
    hi there bought my son a cheap $35 Helicopter
    theres is a problem with it now it doesn't what to fly it only spins and doesn't lift off the ground any more
    was wondering would someone know whats wrong with it?
    cheers
    Might help if we knew what type it was Eg coaxial, fixed pitch etc.
    I'm going to assume its coaxial. I had one that wouldn't take off, turned out to be a broken rod between the upper and lower blades.
      Was the problem after you crashed it?
        Maybe it doesn't spin as hard? (Stuffed batteries ) I got some cheap rechargables off eBay they lasted about half a dozen recharges before being stuffed. I now only get rechargables locally.
          Problems that effect rc helicopter lift.
          1. Not enough head speed and/or collective pitch.
          2. Spinning may be due to the gyro not holding the tail with enough pitch on the tail blades, if no tail rotor and counter rotating blades, problems with the motors that control each set of blades. The gyro needs adjusting. Or see the first note.
          Hope this helps
            thanks for the replies
            just had a closer look at the helicopter and one of the nylon gears are stripped
            the chopper I have is a EV01 Gyro RC Helicopter
            is there anywhere I can by a new nylon gear?
            cheers
              Buy a new one and keep that one for spares. Its $35. I reckon a gear would be $10 even if you found one.
