Traxxas "x"
  • Traxxas "x"
    at the traxxas.com web site, theres a spinning "x" for some new product.its been up for a few days.i got to hand it to traxxas, when it comes to new releases man they keep it hidden well, just about everyone else have leaks worse then a sieve
    wonder if it will be a pulse jet powered 1/5 scale erevo? now that would be awesome!
    Ok for RC noobs like me what is it?
      dunno mate, no body does at the moment
      traxxas are very very good at keeping products under wrap. theres much speculation as to what it could be
      we are all just going to have to wait and see my friend
        I have been out of the RC scene for a while , is Traxxas now the best brand for RC. Id bought a 1/8 Kyosho Inferno Us Sports a while back, its pretty awesome. But it must be dated by now id imagine
        My Youtube Channel: http://www.youtube.com/user/vcoleiro1/videos?view=0
          i dunno if Traxxas is the best or not, we can argue that for many pages. however, i do like traxxas products. mind you, they are not the be all end all of r/c cars/trucks, many other great products out there,
          team associated
          http://www.teamassociated.com/
          hpi
          http://www.hpiracing.com/
          losi
          http://www.losi.com/
          tamiya
          http://www.tamiya.com/
          theres plenty more that are great quality an have great spares/support
            a few datasheets about car
            The Traxxas XO-1 1/7th scale brushless onroad car is now live at http://Traxxas.com
            • 100+mph Out of the Box!
            • NEW Castle Creations Mamba Monster Extreme Speed Control
            • NEW Traxxas Big Block Brushless Motor, Powered by Castle
            • NEW TQi 2.4GHz Radio System with Docking Base*
            • NEW Integrated Speed, RPM, temperature, and voltage Telemetry System*
            • Factory Equipped with two Traxxas Power Cell 3S 5000mAh LiPo batteries
            • All Wheel Drive
            Traxxas? is The Fastest Name in Radio Control?. For over 25 years, we have made it our mission to innovate. To lead. To find the next level of performance and capability. We are driven by a passion for speed and power, and now Traxxas has redefined the meaning of both. State-of-the-art technology. Cutting edge design. A total focus on quality and precision. All have been distilled into one vehicle that could only come from Traxxas. 0-60 in 2.3 seconds. 0-100 in 4.92 seconds. Top speed over 100mph! Simply put, the XO-1 is the world's fastest Ready-To-Race? radio controlled supercar.
            The Next Generation of Traxxas 2.4GHz Control
            XO-1 is equipped with the world's most advanced Ready-To-Race? radio system. The all-new Traxxas? TQi™ radio system with Docking Base turns your iPhone? or iPod touch? into a powerful tuning tool. The device display combines with the Traxxas Link™ App to deliver an intuitive, high-definition, full-color graphical user interface that optimizes your radio system for ultimate vehicle control. Automatic model recognition instantly recalls your settings for up to 30 Traxxas Link-enabled models—just switch on and drive. This powerful App gives you complete control over the operation and tuning of XO-1 with an intuitive, high definition graphical user interface. Once you have created the perfect control settings for your model, you can save them as a profile that you can restore later, use on another model, or share with friends. Traxxas Link telemetry sensors transmit real-time data including speed, RPM, temperature, and battery voltage with stunning visuals.
            Heavy-Duty Drivetrain
            High performance must come with high durability. Traxxas delivers with a robust shaft-driven AWD (all-wheel drive) system proven in our most powerful vehicles and enhanced with new features for XO-1. Steel-gear, E-Revo-spec differentials feature reinforcing support bars to increase horsepower handling capability. The extruded aluminum center driveshaft engages the front and rear gearboxes directly, so there are no dogbones or drive cups to wobble or wear. New, telescoping steel-spline (SS) driveshafts with dual CV joints engage the wheels with track-tested, splined 17mm hex hubs. New fine pitch splined steel telescoping driveshafts handle 50% more torque than conventional shafts. Oversized 6X12mm ball bearings spin efficiently at high rpm, run after blistering run
            Ready-To-Race with Included Power Cell LiPos
            "100+mph, right out of the box." That was the goal for XO-1, and Traxxas delivers with everything you need to hit triple digits—including a pair of Power Cell 3S LiPo batteries. Built with custom Traxxas cells and engineered specifically for the high power demands of Traxxas vehicles, Power Cell LiPo packs are fully equipped with Traxxas High Current connectors, Maxx Cable 12-gauge wire, and standard JST/XH balance plugs for long cycle life, maximum run time, and track-shredding punch.
            XO-1 (#6407) SPECS
            Length: 27 inches (686mm)
            Front Track: 11.61 inches (295mm)
            Rear Track: 11.81 inches (300mm)
            Center Ground Clearance: 0.59 inches (15mm)
            Weight: 8.6 lbs (3.9 kg) (w/o batteries) 10.3 lbs (4.67 kg) (with batteries)
            Height (overall): 5 inches (127.5mm)
            Wheelbase: 15.91 inches (404mm)
            Front Shock Length: 3.27 inches (83mm)
            Rear Shock Length: 3.39 inches (86mm)
            Front Tires (pre-glued): Belted Slick Front (4.29" x 1.7")
            Rear Tires (pre-glued): Belted Slick Rear (4.29" x 2")
            Front Wheels: 3.3" Split-Spoke™ (black-chrome) with 17mm splined hex
            Rear Wheels: 3.3" Split-Spoke™ (black-chrome) with 17mm splined hex
            Speed Control Type: Castle Mamba Monster Extreme Forward/Reverse/BrakeMotor (electric)
            Traxxas Big Block Brushless (1650 Kv),
            Powered by Castle
            Transmission: Single-Speed
            Overall Drive Ratio: 9.36 (stock, out-of-box)
            Differential Type: Sealed Hardened Steel Bevel
            Gear Pitch: Module 1.0
            Chassis Structure/Material: 3mm Plate, Dual Plane, 6061-T6 Aluminum
            Brake Type: Electronic
            Drive System: Shaft-Driven 4WD
            Steering: Bellcrank
            Radio System: TQi™ 2.4GHz Radio System with TQi Docking Base
            Top Speed: 100+mph
            Skill Level: 10
            Battery Tray Dimensions: 155mm x 50mm x 29mm (adjustable height and length)
            Included Batteries: Two Traxxas Power Cell LiPo Batteries (LiPo, 3-Cell 5,000 mAh)
            Required Batteries & Charger: 4 "AA" (transmitter) LiPo Battery Charger
            CASTLE CREATIONS MAMBA MONSTER XS ESC SPECS
            Input voltage (cells): 18 NiCad/NiMH 6s LiPo (max: 25.2 volts)Case Size: 2.2"W x 1.9"D x 1.4"H
            Weight: 4.27 ounces (121 grams)
            On-Resistance* (@Trans)–FWD/REV: 0.0003 ohms per phase
            Reverse Delay: Yes, with lockout
            Low Voltage Detection (LVD): Yes, programmable
            traxxas.com web site down, probably cos its getting hammered by people wanting to see the new car
            more info here
            http://www.ultimaterc.com/forums/sho...d.php?t=136346
              Nice - I was about to buy a revo but might wait as this looks pretty cool
                Price?
                  Nice though id probably destroy it in the first hour.. still wanna get a Rustler VXL someday.
                    More info here and video
                    http://www.engadget.com/2011/12/01/t...r-bank-accoun/
                    and the source site
                    http://traxxas.com/products/models/electric/6407xo1
                    Impressive, but for me going at 100Mp/h may seem impressive, but where ware you going to go to do this each time, how is it in cornering. Wonder how drivable it is a slower speeds. and alas whats the go on needing an iphone to unlock this feature. I believe it's goverened to 60mp/h without the iPhone.
                    Still got to admire it, I Prefer bashability over straight line performance
                      So where in Oz can I get a Ben Block kit from ???
                        Price?
                        tower hobbies has it for $1149
                        http://www3.towerhobbies.com/cgi-bin...I=LXBXDS**&P=3
                        ---------- Post added at 09:34 PM ---------- Previous post was at 09:27 PM ----------
                        and the source site
                        im with you, i much prefer an off road vehicle. im sure traxxas must have have shares in apple so the iphone or ipod will unlock the 100mph setup on it.
                        however
                        i like the idea of streching the slash 4x4 chassis which is essentially what they did to create this.now they have a basis for a good off road vehicle now, just change the driveshafts to wheels and the a-arms and your good to go
                        i got an email from www.liquidrc.com and it shows clearly in one of the photos from traxxas in the instructions "warning, risk of fire, injury or death" in the instructions for this vehicle...and its on the page about the lipos to power it with.
                        well at least they are covering all bases i guess..lol
                        be interesting to see who puts up the first video on you tube of their x-1 ploughing in to a solid object and exploding on impact in to a billion pieces
                        ---------- Post added at 09:39 PM ---------- Previous post was at 09:34 PM ----------
                        depends how much money you want to spend?best places to source it from is ebay (yes i know, shame on me) or better yet a hong kong based shop that is known to be good like rcmart.com
                        or
                        rc-model.com.au
                        or also check out tower hobbies and amian hobbies in the usa
                        http://www.amainhobbies.com/
                        if you want to buy from tower or amain, be sure to sign up to their email list. with in a few days you wil get their specials. they do specials for international shipping every few weeks and you can save a small fortune
                        however, if it was me, i wouldnt buy new, get a good 2nd hand one for bugger all from ebay or one of the rc forums
                          Looks sweet however think I'd prefer an offroad basher.
                            this is pretty much the general consensus on all rc forums. dont be suprised if with in the next 6 months traxxas bring out a off road version. i wouldn't be at all suprised if they don't already have it designed and ready to go
