Replacing 20Gb Xbox 360 HDD with 120Gb
  • Replacing 20Gb Xbox 360 HDD with 120Gb
    Before I go out and buy a 120Gb WD SATA drive (WD1200BEVS) from Game Dude, I was just wondering if anyone has successfully updated their Xbox 360 hard drives?
    Any tips or tricks?
    http://titaniumfish.com/2008/10/21/x...de-wd1200bevs/
    I've got a Mini-Q 450 PC with SATA, so I assume it would be fine to use? (instead of having to buy a SATA card)
    I haven't done it myself but a friend did it before the dashboard update
    and has not had any problems even after doing the update.
    I will be doing my own when I have the time and the spare cash.
      Cool. I might buy the drive and try it out.
      I'll use this guide:
      http://forums.xbox-scene.com/index.php?showtopic=660096
        Does it have to be any specific drive or will any 2.5" Sata drive work?
        Brad
          Pretty sure it has to be a Western Digital WD1200BEVS
          The software used (in the above guide) supports WD's only:
          Q. Will this tool allow me to connect a 500 gb drive to my x360 ?
          A. No. The information on sector 16 is signed and can't be changed. You can only use size where you have a valid signature for. In otherwords, if a bigger HDD comes out, you can use that signature.
          Q. With which HDD's does this work ?
          A. As of version 0.91, it now works with all sizes and versions of the Western Digital Scorpio BEVS series.
            Thats a good price from Gamedude, think I might upgrade my 20Gb.
            In 2 Amusements
            Arcade Parts and Accessories
            Email:
              I've done around 20+, can be time consuming copying everything over from the old 20gb HDD to the new one.
              If you have a modded 360 and copy of the Xbox Transfer Disc and a USB to SATA, after you have done the conversion you can auto copy everything across
              MSY in Brisbane had 120GB WD BEVS for $55
              Just be careful of the revision number as I think that one of the later drives can't be done
              Theres some more good info at http://beta.ivancover.com/wiki/index..._Drive_Upgrade
                Ohh good info Schmake! thanks
                Brad
