Sega Master System cart reader / writer
  • Sega Master System cart reader / writer
    Found this cool project that people might be interested in ie putting roms onto a modified SMS cart to play on your original hardware
    http://www.smspower.org/smsreader/
    It plugs into your PC's parallel port (which must operate in bi-directional mode), and is controlled by software running under Windows or MS-DOS. Using the reader, you can:
    * Read your own Sega cartridges and copy the ROM images onto your hard drive, so you can use them in emulators such as Meka.
    * Write ROM images onto specially modified cartridges with battery backed RAM, so you can use them on the real Master System.
    * Read and write your saved games from cartridges like Phantasy Star, which have battery backed RAM for save positions.
    That looks great! good if there was a Megadrive/Genesis one as well.
      I just read the same question on a forum... and was linked to ToToTek.
      Looks like there are all sorts of flash carts here:
      http://www.tototek.com/
      EDIT: Looks like Elvis has mentioned Tototek before
      http://www.aussiearcade.com/showthread.php?t=4178
      Here's a homemade reprogrammable MD cart:
      http://www.raphnet.net/electronique/...is_cart_en.php
        Did a quick check for buying parts in my Jaycar catalogue.
        Most are cheap parts ie under $1.
        Hardest to come by will be inline resistor (tho can just replace with normal resistors) and the edge connector. Not sure where to get one of them (other than hacking open an SMS)
          Could you use an old ISA slot of an old mother board?
          It might need some hacking to size
            As long as the contacts line up it would be possible... hmm
              And here are the mods in my SMS you need to get full value out of having a re-writable SMS cart:
              50/60Hz Mod
              Region Change Mod
              FM Sound Mod
              The 3 wires in a row next to the marking "JP2" are for the 50/60Hz mod
              The wire coming off the 315-5237 chip to a switch with ground connection is for the region change
              The unit plugged into the expansion port with a wire coming off it is the FM sound unit
              Not all SMS model ones are the same, there is plenty of info available on the net though.
              I'll gradually work on the Cart Reader/ Writer device amongst other things........
                Yessir, for my birthday (March 2007) I got both Master System and SNES reflashable carts from Tototek courtesy of my missus.
                Want to know the tragic part? I haven't even used them once yet. No goddamn time to even get that much done.
                  I have finished making the SMS Cart Reader/ writer now. I have read some carts with it and it works fine. I need to get some parts online to make a re-writable cartridge next.
                    very nice!
                    Regards
                    Dez
                    DSB Electrical
                    DSB Electrical Facebook
                    VAPS
                    Vector Monitor Repro Parts
                      sweet. keep us updated with the rewrite cart
                        good to see enthusiasm is still strong for this sort of thing.
                          Nice work. Where did you get the cart slot?
                            I salvaged it from a non - working SMS
                              I received RAM chips from Futurlec for the re-writable cartridge. There is a problem though, they didn't send me the exact same chip as I ordered. Can anybody here tell me what the difference is between the chips, and if the one they sent me might be a suitable alternative?
                              I ordered Hitachi 628128 RAM chips as per this datasheet
                              They sent me Wingshing 628128LLP-70 RAM chips as per this datasheet
                              I am not sure what to look for to determine if what they sent me will work just as well anyway? Can anybody offer advice, I am not up to speed with this stuff yet.
