Xbox original requires repair/TLC
  • Xbox original requires repair/TLC
    Is there anyone within the forums or external who fixes original Xbox's?
    Background; My console wont read discs anymore unfortunately. It is a bone stock console that was repaired about 6 years ago for the same problem.
    Any help appreciated!
    Wanted - Neo Geo AES games (PM me Please)
    Wanted - CPS2 game boards (PM me Please)
    Watching as my Xbox keeps shutting off
    interested to know if their are repairmen around for these units
      Dirt and dust on the laser. Compressed air in the DVdrive maybe or else pull machine apart, remove DVDrive, pull screws out, remove lid of DVDrive and manually clean the crap off the laser.
      Yours is somewhat harder but still relatively easy to fix.
      Absolutely nothing you have done but the finger acids on the Chinese assemblers fingers that assembled your machine originally. This video shows you "exactly" how to repair it.
        I would mod it. Bypass the optical, save your discs, play backups. Perfectly legal and reasonable way. The mod nowadays is a bios mod, so no modchip. I'm about to do two of them for myself, but haven't done it yet so I'm just talking from my reading.
        Sent from my HTC 2PZF1 using Aussie Arcade mobile app
          What video?
          nothing is showing sorry
            What video?
            Sorry, my bad....This video. It is referring to trace corrosion.
            The problem occurred when the board was handled, flipped over actually on the assembly line prior to the board lacquer being applied. Acid from the worker's fingers got onto the raw copper traces, ( very common to be able to see fingerprints under the lacquer), and this acid over time eats away the traces/ traces. You can often see the damaged traces by eye in that one part of the board the video points to.
            To repair, you bridge out the damaged section of trace or traces by following the trace back to the nearest solder point. solder to that solder joint and do the same the other way so your link forms a bridge over the damaged section of trace.
            Once done your machine should be fine. If you find no corrosion on these group of traces start looking around the supa capacitor. Get back to me if you need help with that type of repair.
              https://youtu.be/SQxbSMo3I0Q?t=29
              Sorry for not replying sooner
              the above sounds like what is needed but well above my skills
              I'll see about taking it to someone to look at perhaps but thanks again for the reply
