Snes floppy disk copier
  • Snes floppy disk copier
    Ok, I just payed $XX for one of those floppy disk drive's for snes called Supercom Parnter. what are they typically worth? i wanna know if i got ripped off or not..
    Depends on the amount of ram they have, but less than $100 for a 32MBIT version is pretty good.
      Phew... thats a releif. Whats the most i could probably sell it for?
        I got one recently - I paid $65 plus postage, and it came with an NTSC SNES and about 4 or 5 controllers - so basically it was a steal! It is fully working playing the games from floppies but I don't think its cartridge-reader is working (which is fine - if I've got the Cart I hardly need it to read it for me!) I'd say they're worth no more then about $75.
          Damm i remember these things,,I had one about a month after the super fami came out.. About a year or 2 before they hit OZ.. Lots of hours spent on that baby!
            Ok, it just arrived today with a Super famicom..
            Before i power it up.. is it safe to use an aus snes power supply?
            i dont want to blow it up
              i am unsure but check the voltages on the adaptor and the console i cant see there being any conflict.
                the aus power supply is not compatible with a super famicom or copier (i have a sf7)...
                  Ok.. I just read on the net that a Nes Aus power supply does work on a super famicom, Well i pluged it into mine and nothing happened. No explosion and no light signaling its on...
                  Does that the mean the previous owner has tried something similar and blown it up??
                  Would it be an easy fix? or is it totally ****ed
                  EDIT: Swaped fuses with one from my broken snes and it works!
                  But the Copier still doesn't.... Does anybody know where i could get something like that fixed?
                    I pretty sure that the SCP takes the same power supply as UFO/GD etc, which is DC 9V or the exact same plug that the Aussie Megadrive/SMS uses.
                    My memory is rusty with that unit, however some units will still power on (display on-screen) without the PSU plugged in, just the Disk drive won't work. Some require a cartridge to be plugged in.
                    I'd take it apart to see if the onboard battery has corroded or for other visible signs of distress
                      If the copier is designed for PAL then you need to disable the lockout chip in an NTSC unit.
